Thread: G6 Heated seat install
Results 1 to 11 of 11
  1. #1 G6 Heated seat install
    Jun 2015
    KS
    ok guys looking for info on what wires i need to hook up to get the heat to work on these leather g6 seats
  2. #2 Re: G6 Heated seat install
    GTX Level Member wstefan20's Avatar
    Aug 2017
    Raytown, MO
    Hm didn't know they would bolt right in. Interesting... What year is your vehicle and I can tell you for sure
  3. #3 Re: G6 Heated seat install
    St. Louis
    They shouldn't since they come from a completely different platform. Unless someone modded the rails to make it work somehow.
  4. #4 Re: G6 Heated seat install
    Aug 2017
    Raytown, MO
    Quote Originally Posted by FordMan77 View Post
    That's what I thought. I've got the wiring diagram, but not sure if the op has tried actually putting it in before I waste time on matching the wiring.
  5. #5 Re: G6 Heated seat install
    I'd pull the two diagrams and see where they are similar. G6 might have a Dash Integration Module since it's newer and may be a little tougher to wire in if it needs something beyond a module under the seat to control it.
  6. #6 Re: G6 Heated seat install
    Aug 2017
    Raytown, MO
    G6 seats are actually easier since there's no data and the seat heater button is on the seat. Only has a few power wires and a ground. Wiring isn't the issue, it's the rail fitment.
  7. #7 Re: G6 Heated seat install
    Jun 2015
    KS
    i know they dont bolt right in i had brackets made for one car another one i drilled threw the body and used grade 10 bolts and washers and just bolted threw the body what im looking for is the wire diagrams how to get the heated part to work. ive been on this forum 4 yerars im still trying get my old profile back
  8. #8 Re: G6 Heated seat install
    Aug 2017
    Raytown, MO
    Nice! I can't wait to see how it looks and how you did it! Those seats are super comfortable. I've got the schematics but are you talking swapping into a 97-03 or a 04+ here?
  9. #9 Re: G6 Heated seat install
    Jun 2015
    KS
    Quote Originally Posted by wstefan20 View Post
    04+ ill set one in and take a pic and try figure out how get it on here lol
  10. #10 Re: G6 Heated seat install
    Aug 2017
    Raytown, MO
    Ok cool! I'll post the schematics in a bit. Out to dinner
  11. #11 Re: G6 Heated seat install
    Aug 2017
    Raytown, MO
    Ok. Sorry for the delay. So, if you have an 04, you might have the old style wiring because gm decided to be screwy and only partly change things in 04. Let me know if this is the case. Otherwise, you'll basically only need four wires. You'll connect pin A orange from gp to pin A red/blk g6, pin C orange gp to pin J red/wht g6, It doesn't list the pin for the ground wires, but they're both the only black wires, so connect those (there's a very slight possibility there is no ground wire on the g6 and the ground is through the frame, in which case don't worry about it), the only wire you'll have to run is an accessory wire (so you can't accidentally burn your car down when you leave the heated seat on). Probably easiest place to tap in is the brown wire running down your steering column (make sure you check before using by verifying function with a test light etc).
    If you're installing the passenger seat as well, let me know and I'll pull the schematics too!
  1. heated seat
    By ranchero in forum Introductions/Noob Questions
    Last Post: 01-03-2017, 07:35 PM
  2. Replies: 1
    Last Post: 08-01-2014, 11:22 AM
  3. 97-03 OEM heated seat switch for passenger wired to aftermarket heated element?
    By Hardonyomom in forum Audio, Security & Visual Electronics
    Last Post: 01-29-2014, 03:59 PM
  4. my heated seat
    By chevymomma in forum General Grand Prix Discussion
    Last Post: 12-29-2011, 02:02 AM
  5. heated seat
    By Ricky21 in forum General Tech Discussion
    Last Post: 04-23-2010, 10:43 PM
