Thread: #04-07-30-013B: Info - Automatic Transmission - TSB - Oiled K&N Performance Filters
Results 1 to 4 of 4
moddman #04-07-30-013B: Info -... 05-07-2015, 07:51 AM
moddman Re: #04-07-30-013B: Info -... 05-07-2015, 07:52 AM
moddman Re: #04-07-30-013B: Info -... 05-07-2015, 07:53 AM
moddman Re: #04-07-30-013B: Info -... 05-07-2015, 07:55 AM
  1. #1 #04-07-30-013B: Info - Automatic Transmission - TSB - Oiled K&N Performance Filters
    Donating Users moddman's Avatar
    Midwest
    http://ww2.justanswer.com/uploads/he...07-30-013B.pdf
    http://troubleshootmyvehicle.com/gm/...e-maf-sensor-1
    Shift, Engine Driveability Co
    ncerns or Service Engine
    Soon (SES) Light On as a Result of the Use of an
    Excessively/Over-Oiled Aftermarket, Reusable Air
    Filter - (Feb 1, 2007)
    This bulletin is being revi
    sed to add models and mode
    l years. Please discard
    Corporate Bulletin Number 04-07-30-013A (S
    ection 07 -- Transmission/Transaxle).
    The use of an excessively/ove
    r-oiled aftermarket,
    reusable air filter may result in:
    The oil that is used on these air filter elem
    ents may be transferred onto the Mass Air Flow
    (MAF) sensor causing contamination of the sens
    or. As a result, the Grams per Second (GPS)
    signal from the MAF may be low and any or al
    l of the concerns listed above may occur.
    When servicing a vehicle with any of these concer
    ns, be sure to check fo
    r the presence of an
    aftermarket reusable, excessively
    /over- oiled air filter. The
    MAF, GPS reading should be
    compared to a like vehicle with an OEM air box
    and filter under the same driving conditions to
    verify the concern.
    The use of an aftermar
    ket reusable air filter DOES NO
    T void the vehicle's warranty.
    If an aftermarket reusable air f
    ilter is used, technicians should inspect the MAF sensor element
    and the air induction hose for contamination
    of oil prior to making warranty repairs.
    Transmission or engine driveabi
    lity concerns (related to the MAF sensor being contaminated
    Subject: Automatic Transmission
    Concerns or Service Engine
    Aftermarket, Reusable Air Filter
    Models: 2007 and Pr
    ior GM Cars and Light Duty Trucks
    2007 and Prior
    Saturn Models
    2003-2007 HUMMER H2
    2006-2007 HUMMER H3
    2005-2007 Saab 9-7X
    DO THIS
    DON'T DO THIS
    First, Inspect the vehicle for a
    reusable aftermarket
    excessively/over- oiled air filter
    DO NOT repair MAF sensors under warranty if
    concerns result from the use of an
    excessively/over-oiled af
    termarket, reusable air
    filter.
    • Service Engine Soon (SES) light on
    • Transmission shift concerns, slipping and damaged clutch(es) or band(s)
    • Engine driveability concerns, poor acce
    leration from a stop, limited engine RPM range
    with oil) that are the result
    of the use of an afte
    ssively/over-oiled air
    filter are not considered to be warrantable repair items.
    GM bulletins are intended for use by professional technicians,
    NOT a "do-it-yourselfer". They are written to inform these tech
    nicians of conditions that
    may occur on some vehicles, or to provide in
    formation that could assist in the proper
    service of a vehicle. Properly trained t
    echnicians have the
    equipment, tools, safety instructions, and know-how to do a job
    properly and safely. If a condition is described, DO NOT assum
    e that the bulletin
    applies to your vehicle, or that
    your vehicle will have that condition. See yo
    ur GM dealer for information on whether your veh
    icle may benefit from the
    information.
  2. #2 Re: #04-07-30-013B: Info - Automatic Transmission - TSB - Oiled K&N Performance Filte
    Midwest
    3.4" ZZP MPS Pull
    ey,ZZP Coupler,NGK PLUGS,L67 Coils,INTENSE 1.8 RR, Custom PCM Tune, ZZP Stage 2 IC, 180* T-Stat, 42LB RE-FLWD Inj.
  3. #3 Re: #04-07-30-013B: Info - Automatic Transmission - TSB - Oiled K&N Performance Filte
    Midwest
    moddman:K&N Oiled Filters Bulletin - Been There Before:http://ww2.justanswer.com/uploads/he...07-30-013B.pdf
    moddman:http://shop.advanceautoparts.com/p/c...content=120917
    moddman:Works wonders for Oiled Type K&N or Oiled Type Spectre Performance Filters causing driveabilty problems.
    moddman:Used On the MAF.....
    moddman:Just wanted to share good info
    GMR Badass:we all know that a k&N filters no good for the maf
    moddman:And Spectre oiled included
  4. #4 Re: #04-07-30-013B: Info - Automatic Transmission - TSB - Oiled K&N Performance Filte
    Midwest
  1. What automatic transmission fluid to use
    By raverockstar in forum General Grand Prix Discussion
    Last Post: 03-21-2014, 03:49 PM
  2. 98 GTP Automatic Transmission Problems
    By ricksowers in forum Introductions/Noob Questions
    Last Post: 08-19-2013, 05:43 AM
  3. Automatic Transmission advise
    By Severoux in forum Pre-1996 4 speed Automatic (4T60E)(4T60E-HD)
    Last Post: 02-21-2011, 09:42 AM
