Thread: Core support dog bone bushing removal (the easy way)
Results 1 to 13 of 13
sampuppy1 Core support dog bone bushing... 04-11-2017, 12:56 PM
CHI2000GTP Re: Core support dog bone... 04-11-2017, 03:45 PM
cheatah faheatah Re: Core support dog bone... 04-11-2017, 03:48 PM
sampuppy1 Re: Core support dog bone... 04-14-2017, 12:50 AM
bachert24 Re: Core support dog bone... 05-04-2017, 07:56 AM
Professor X Re: Core support dog bone... 06-18-2017, 11:53 AM
bachert24 Re: Core support dog bone... 06-18-2017, 03:53 PM
sampuppy1 Re: Core support dog bone... 06-18-2017, 05:39 PM
Scottydoggs Re: Core support dog bone... 06-18-2017, 05:50 PM
sampuppy1 Re: Core support dog bone... 06-19-2017, 08:38 AM
blueguy91 Re: Core support dog bone... 06-19-2017, 03:29 PM
sampuppy1 Re: Core support dog bone... 06-20-2017, 03:29 PM
wstefan20 Re: Core support dog bone... 12-01-2017, 10:10 PM
  1. #1 Core support dog bone bushing removal (the easy way)
    GT Level Member sampuppy1's Avatar
    Mar 2016
    Looked for awhile and didn't see any posts on this so I thought I would share my positive experience while contributing to the forum.
    First step - buy poly bushings. The rubber ones were worn, and my removal method will not work for install. I suppose, if one was so inclined, you could make your own as well. But, I was at ZZP anyways so in the name of f*ck it, I bought a set.
    This process is easiest to do one at a time. Leaving one side hooked up keeps the engine oriented and makes the job simpler in my opinion.
    Step 2 - remove a dog bone, and find a ratchet strap.
    Step 3 - tie a figure 8 or clove hitch or similar non slipping knot on the bolt head end with the hook side of the strap. I prefer the figure 8 as it takes up less space and always tie a safety knot to prevent unwanted slippage. I also used a spare section of strap left over from a tail I shortened for a marine application.
    Step 4 - insert bolt into bushing with nut on exterior facing side. Attach ratchet end to opposing dog bone core support mount or other stable location.
    Step 5 - run strap through ratchet and start cranking. Once you get good tension on the bushing make sure the strap is firmly secured to the bolt and won't slip over the bolt head. Then continue tightening until the bushing begins to tear. After that physics pretty much handles the rest and the center section will rip enough to allow the rest of the rubber to fold up and flop right out. If you wish to make it interesting you can keep cranking away until it flies out but I aired on the side of caution in this case.
    Step 6 - install new poly bushing and reattach dog bone.
    Repeat mirror process for opposing side.
    Start to finish this way took me a good ten minutes. Not accounting for the half hour of fiddle f*cking around with other unsuccessful methods.
    Sent from my XT1254 using Tapatalk
  2. #2 Re: Core support dog bone bushing removal (the easy way)
    GTP Level Member CHI2000GTP's Avatar
    Dec 2015
    Chicago, IL
    I'll try this method when the times comes. Not a bad idea. I've heard of cutting them out, chiseling them out, and one guy on here said he melted them out... However, this approach seems like it gets the job pretty cleanly and efficiently.
    2000 GTP 4DR - Stock
    243,000 miles
    CHICAGO, IL
    My Car: http://www.grandprixforums.com/members-rides/103740-lukes-gtp.html#post1443981
  3. #3 Re: Core support dog bone bushing removal (the easy way)
    GTX Level Member cheatah faheatah's Avatar
    May 2016
    Rouge Island
    Fiddle Fvcking is one of my favorite pastimes....
    For the record : I am NOT a naked meth-head who shoves rocks up my butt.
  4. #4 Re: Core support dog bone bushing removal (the easy way)
    Mar 2016
    Quote Originally Posted by CHI2000GTP View Post
    I tried cutting them with a buck knife. A sharp one. Images of busted up knuckles or sliced open fingers from slipping kept me from using too much force and it was just not something I felt comfortable continuing along with. Bleeding out is not my favorite past time.///// I don't see how chiseling rubber is even possible. And I tried ripping chunks off with pliers and it worked but after 10 mins of cutting, pounding, ripping and wasting time...... I hadn't even made it halfway through the top part.///// Melting........ Yeah....... Firefighter here. Not a fan. If your 3.8 leaks flammable engine lubricants like mine does.......lighting rubber on fire near that front valve cover just doesn't seem like that great of an idea.///// my method works, is clean, and requires little to no effort. Just have to know how to tie a good knot.
    Quote Originally Posted by cheatah faheatah View Post
    Mine too. But I have to go back to work next week and I don't have the time to waste anymore. Layoff season is over. It's crunch time.
    Tyler/T-Unit
  5. #5 Re: Core support dog bone bushing removal (the easy way)
    GT Level Member bachert24's Avatar
    Jan 2015
    I just used my jigsaw to cut across the top and bottom of the mount. Pulled out the metal center, lifted out the rest with a flat head screwdriver.
    Sent from my LG-LS993 using Tapatalk
  6. #6 Re: Core support dog bone bushing removal (the easy way)
    Jan 2016
    Tucson, AZ
    Any tips for installing the new bushings? Rubber ones? Thank You
    X
  7. #7 Re: Core support dog bone bushing removal (the easy way)
    Jan 2015
    Quote Originally Posted by Professor X View Post
    X
    They slide right in
  8. #8 Re: Core support dog bone bushing removal (the easy way)
    Mar 2016
    X
    I'd grease the **** out of them or buy poly ones.
    Quote Originally Posted by bachert24 View Post
    They slide right in
    The rubber ones I'm not sure on. I haven't seen the replacements. My poly ones went in like a breeze.
    Sent from my XT1635-01
    Tyler/T-Unit
  9. #9 Re: Core support dog bone bushing removal (the easy way)
    new stock junk comes in new brackets that bolt to the rad support
  10. #10 Re: Core support dog bone bushing removal (the easy way)
    Mar 2016
    That sounds simpler yet.
    Tyler/T-Unit
  11. #11 Re: Core support dog bone bushing removal (the easy way)
    May 2017
    Dirtyzville, Mizzery
    Sawzall is much easier and probably about 27.4 times safer.
    1999 Chevrolet Silverado K1500 Classic Z71 - Intake/Gibson Exhaust/20% Tint
    2004 Chevrolet Corvette MRM A4 - C5Z Suspension/AFE S2 Intake/TSP Catless LT's/3" ORX/C6 ZR1 Wheels
    Sold WBody's: '98 GT, '98 GTP, '03 GTP, '05 GXP
  12. #12 Re: Core support dog bone bushing removal (the easy way)
    Mar 2016
    Easier? Maybe with a small jig saw. Smaller blades would probably make it easier. But I didn't have one, and I wasn't gonna buy one for this.
    As far as safer, I was patient and used just enough tension for the rubber to start giving. And I stayed on the side away from the pull. I fully trust my knot tying capabilities as a firefighter I have to be good with them as I might have to trust my life to a knot I tied in the dark with gloves on.
    Tyler/T-Unit
  13. #13 Re: Core support dog bone bushing removal (the easy way)
    GTX Level Member wstefan20's Avatar
    Aug 2017
    Raytown, MO
    I just used this method (except I was exceptionally lazy and I just wrapped the ratchet strap around the core, used some lube (always necessary), and POP! Think it look me maybe two minutes? Glad I found this post before I did this. Nice work!
  1. Dog Bone bushing and Upper Motor Mount.
    By Brammer in forum General Grand Prix Discussion
    Last Post: 10-18-2013, 04:55 PM
  2. Subframe bushing removal? Help....
    By Mr D in forum Brakes/Suspension/Chassis
    Last Post: 07-29-2013, 08:19 AM
  3. Core Support
    By boothe in forum General Tech Discussion
    Last Post: 03-29-2012, 05:17 PM
