Thread: What to do with your old Onstar system (or just for fun!)
Results 1 to 6 of 6
  1. #1 What to do with your old Onstar system (or just for fun!)
    GTX Level Member wstefan20's Avatar
    Aug 2017
    Raytown, MO
    Not much on the way of write-up, but just a quick suggestion since the Onstar systems for our cars are completely useless now, but here is what I did to make use of the cover, and provide some added safety in the meantime:
    As you can see, this $20 harbor freight fire extinguisher fits great under the cover with slight modifications. All I did was trim to about 1/2" thickness around the trim on the hinge side and removed the "shelf" the onstar vcim bolts to to free up space for the fire extinguisher. I'm sure there's plenty of things you can hide under here, this was just what I wanted to cover up, so use your imagination and post your ideas here!
  2. #2 Re: What to do with your old Onstar system (or just for fun!)
    Kemmerer, Wyoming
    I love it, was removing the actual onstar module pretty simple?
  3. #3 Re: What to do with your old Onstar system (or just for fun!)
    SE Level Member GrandPrixGT1's Avatar
    Jan 2017
    Mount Airy, MD
    I believe its just bolted in there. Wiring harness you could just cut. Thats a really cool idea tho. What size fire extinguisher is that?
  4. #4 Re: What to do with your old Onstar system (or just for fun!)
    Aug 2017
    Raytown, MO
    No need to cut wires. There's a harness connector up above, you just tuck it away. The bracket is held on with two 12mm bolts (I think) top and bottom, and there's four Philips screws holding the on star module in and a strap around vcim. Just unplug connectors and you're off!
    I actually added this using self tapers. Got from a junkyard. And used a cut off wheel to cut.
    Here's the link: https://m.harborfreight.com/2-lb-fir...ver-62634.html
  5. #5 Re: What to do with your old Onstar system (or just for fun!)
    Kemmerer, Wyoming
    I think a bottle of nitrous would be cool
  6. #6 Re: What to do with your old Onstar system (or just for fun!)
    Aug 2017
    Raytown, MO
    Good idea! Maybe a drink dispenser?
  1. Back window replacement - non-onstar vs onstar glass
    By 2004l67 in forum General Tech Discussion
    Last Post: 06-05-2015, 08:04 AM
  2. Onstar mic.
    By duane9586 in forum Audio, Security & Visual Electronics
    Last Post: 01-18-2015, 12:11 AM
  3. 2004 Grand Prix GT. Service ABS System, and Taction Control System
    By Erika Schultz in forum Brakes/Suspension/Chassis
    Last Post: 04-01-2012, 05:26 PM
  4. OnStar
    By gpgt in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-02-2009, 05:11 PM
  5. OnStar standard???
    By Randy_W in forum Off Topic Discussion
    Last Post: 06-26-2008, 11:56 AM
