Thread: Axle Seal Replacement [*]
Results 1 to 8 of 8
  1. #1 Axle Seal Replacement [*]
    SE Level Member Metallistar's Avatar
    This HOW TO write-up on Replacement of the Axle Seals, has been added to the How To section and can be found HERE.
    Is their a write up on how to replace the drivers side axle seal? Mine seems to be seeping out tranny fluid.
  2. #2 Re: Axle Seal Replacement
    Transmission Expert Trannyman95's Avatar
    Fort Wayne, IN
  3. #3 Re: Axle Seal Replacement
    Oklahoma
    Good Lord Trannyman, you knowledge never ceases to amaze me. Awesome info and definitely add that to your list to do with pictures, LOL.
    Im going to have to take some vacation and come up there and help you out.
  4. #4 Re: Axle Seal Replacement
    You are the man! Thanks!
  5. #5 Re: Axle Seal Replacement
    Trannyman95,
    Thanks again, I swapped out the seals and no more leak! I ended up using a large socket I had to press the new seal in. Worked like a charm.
  6. #6 Re: Axle Seal Replacement
    Fort Wayne, IN
    Glad to hear you got it fixed ok!
  7. #7 Re: Axle Seal Replacement [*]
    Minnesota
    Can this link be fixed....It's not working for me?
  8. #8 Re: Axle Seal Replacement [*]
    Bunnell, FL
    all the diy links don't work
    so good luck w/ that. try gm tech book?
    I'm a Sex Offender
  1. CV Shaft Replacement [*]
    By webracin in forum How To Write-Ups/Tech Tips
    Last Post: 01-05-2012, 09:22 AM
  2. Drive Belt Replacement [*]
    By 03GPScottyd in forum How To Write-Ups/Tech Tips
    Last Post: 05-24-2009, 05:44 PM
  3. PVC Valve Replacement (L67) [*]
    Last Post: 02-18-2008, 06:43 PM
  4. PCV Valve Replacement (L36) [*]
    Last Post: 01-03-2008, 11:25 PM
