Thread: 2006 GXP Struts to choose?
Page 2 of 2 FirstFirst 12
Results 21 to 27 of 27
  1. #21 Re: 2006 GXP Struts to choose?
    Oct 2014
    Ohio
    Anyone have there harmonic balancer move slightly side to side. Enough to see the belt move side to side and you can see that it is eating the belt up.
  2. #22 Re: 2006 GXP Struts to choose?
    I live here. DirtDog's Avatar
    Jun 2012
    Time for new balancer. I had to replace mine.
  3. #23 Re: 2006 GXP Struts to choose?
    Oct 2014
    Ohio
    Gotcha.
    I found one on rock auto for about 176.00. You know of any where else cheaper?
    I assume I need a new bolt as well right
  4. #24 Re: 2006 GXP Struts to choose?
    Arizona
    That's all you'll need. If you're doing yourself you'll need a vice grip for the flex plate and a impact gun or stupid long breaker bar. Oh and a Chrysler 3 jaw puller
  5. #25 Re: 2006 GXP Struts to choose?
    Oct 2014
    Ohio
    Why do I need to hold the flex plate? Pulley shouldnt move if I am using an impact gun.
    I can see needing to hold flex plate if I didnt have an impact gun.
  6. #26 Re: 2006 GXP Struts to choose?
    Arizona
    The bolt is at 240lb ft plus a couple degrees of stretch with thread sealant on it. Even with an impact it'll still rotate the crank. Holding the flex plate with the vice grips keeps that from happening
  7. #27 Re: 2006 GXP Struts to choose?
    Oct 2014
    Ohio
    Even with a 450lb ft impact gun you think it will still move that crank?
    Where are you putting vise grips on the flex plate?
  1. which cam would you choose
    By Cobras 98 Prix in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-14-2012, 12:31 PM
  2. Help me choose.
    By Silver2kgtp in forum Tires & Wheels
    Last Post: 02-16-2012, 03:40 PM
  3. 2006 GT, time for new struts/shocks?
    By huttler in forum Brakes/Suspension/Chassis
    Last Post: 12-12-2011, 09:28 AM
  4. What would you choose and why?
    By m17davis in forum General Tech Discussion
    Last Post: 12-22-2010, 10:57 PM
  5. help choose
    By NickR in forum Visual/Body Modifications
    Last Post: 07-03-2009, 11:03 PM
