Thread: throttle body cleaning
Results 1 to 15 of 15
  1. #1 throttle body cleaning
    May 2011
    winnipeg
    Can anybody tell me if it is ok to push open the throttle butterfly with a finger, to spray cleaner into the bore? I am working on an 04 pontiac
    grand prix and I want to clean the air intake because it is pretty dirty. Is it best to unplug the wire harness?
  2. #2 Re: throttle body cleaning
    GTX Level Member cerick08GP's Avatar
    Yup, using your finger is the best way IMO.
    I unplug the harness...it only takes 5 seconds.
    Ten years of continuous driving excitement and counting!
    2008GP
    ||HV3 insert||PowerSlot rotors w/Hawks||LED interior||MSD 8.5mm
    2002GP||sold
  3. #3 Re: throttle body cleaning
    GTP Level Member buickman104's Avatar
    NYC
    If you are supercharged you don't wanna use any cleaning solutions. They can destroy your rotor coating.
    2000 Bronze Metallic GTP
    Power :Gen V, 3.6 pulley, 3 inch down pipe, Power log, FWI,and DHP Power Tuner,
    Handling: Vogtland Springs, GMPP sway bars, STBS, 18" Konig backbone, CTS-V Front brakes and GXP rear brakes
  4. #4 Re: throttle body cleaning
    Pennsylvania
    yeah, don't spray IN the intake... And remember to leave it propped open for a while to evaporate. An intake full of tb cleaner doesn't combust just right...
  5. #5 Re: throttle body cleaning
    SE Level Member 03limitedgtp's Avatar
    Sep 2011
    ohio!
    what would you use then because i'm wanting to do the same thing to my gtp
  6. #6 Re: throttle body cleaning
    Pennsylvania
    Do not fill your intake with throttlebody cleaner. Just scrub down the throttlebody plate with throttlebody cleaner and call it a day.
  7. #7 Re: throttle body cleaning
    Pennsylvania
    It only takes like 5 minutes to remove the tb from the car, 4 bolts.. and then you can go to town with a rag on both sides, then get a rag wet with tb cleaner and wipe down as far as you can reach into the intake.
    Sport Edition Kv5 18x8
  8. #8 Re: throttle body cleaning
    Quote Originally Posted by FriboRage View Post
    This is the best way to clean a throttle body. I'd highly recommend it to anyone that has not cleaned their TB. Amazing what a difference it makes.
  9. #9 Re: throttle body cleaning
    May 2011
    winnipeg
    Thanks for the info, I think I will try my hand at taking it off. Probably get a much better clean and from what I read it should be simple.
  10. #10 Re: throttle body cleaning
    GTX Level Member 97gtpjoe's Avatar
    Jan 2009
    Chandler, Arizona, United States
    Quote Originally Posted by dlk View Post
    While reading his thread I pulled, cleaned and , replaced TB . Freaking easy lol .
    Speed Daddy Headers, Open Cone, 3.4 MPS , AL605s , 180* Stat
  11. #11 Re: throttle body cleaning
    Sep 2011
    ohio!
    what about the pedal strings do they have to be re-adjusted?
  12. #12 Re: throttle body cleaning
    nope, take them out, take tb off, put back on and clip them back into place.
  13. #13 Re: throttle body cleaning
    Houston
    I was gonna clean it since I hadn't in the 6 years that I've owned it. Then I saw this and said I'll check it again in 6 more years.
  14. #14 Re: throttle body cleaning
    Pennsylvania
    Woah.
  15. #15 Re: throttle body cleaning
    Pennsylvania
    EGR delete maybe?
  1. Cleaning Throttle Body
    By klj5022 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-31-2012, 08:00 AM
  2. Cleaning the IAC, MAF and throttle body
    By Nicolecc2 in forum Engine
    Last Post: 08-29-2011, 08:48 PM
  3. cleaning throttle body
    By mtz956 in forum General Tech Discussion
    Last Post: 06-15-2011, 06:29 AM
  4. Throttle Body Cleaning
    By Bryan921SS in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-14-2010, 01:44 PM
  5. Cleaning Throttle Body 04-GP
    By mpbrown18 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-11-2010, 12:29 AM
