Thread: 1997 grand prix ventilation problem!
Results 1 to 6 of 6
  1. #1 1997 grand prix ventilation problem!
    Banned
    canada
    when I change the mode from vent to floor, floor to vent, etc., there is no change in the direction of air flow through the venting system. Any help with this please?
  2. #2 Re: 1997 grand prix ventilation problem!
    Oct 2008
    Calgary, Alberta
    probabaly the vacumme line to the controller is cracked, I replaced mine with a piece of metal brake tubing passing through beside the automatic shifter cable (stock goes through a wiring harness)
    ps some people see multiple posts from the same person in different sections and ignore them all, i section works. (most do a view todays posts and see all of them anyway.)
  3. #3 Re: 1997 grand prix ventilation problem!
    Banned
    canada
    thnx for the info! but my climate control is manual it has many hoses behind the dial knob! could u plz tell me where exactly the and which exactly vacuum line i should be checking thnx again!
  4. #4 Re: 1997 grand prix ventilation problem!
    Oct 2008
    Calgary, Alberta
    the vacumme line comin g from the engine should be a hard black plastic line with a black rubber elbow. I have not seen a non-auto climate controller so I can't con firm exactly where it goes. but it should enter a wiring harness that passes through the firewall, check for vacumme here. You will probabaly have to look from under the glovebox on the passanger's side. The port on the engine should be one of the tees on top of the supercharger. (unsure about 97's 98+ are tied in beside the brake booster vacumme.)
  5. #5 Re: 1997 grand prix ventilation problem!
    GTX Level Member noreasonwhyy's Avatar
    Michigan
    it's likely a vacuum line or your blend door motor/s.
    97 GT - slow, rusty
    93 CTD - more slow, less rust
  6. #6 Re: 1997 grand prix ventilation problem!
    Banned
    canada
    Alright thanx for the advice! i will start working on it this coming weekend! hopefully i will find the troubleshoot before snowfalls here in toronto ontario canada
  1. Ventilation problem
    By Viperkill97 in forum General Tech Discussion
    Last Post: 07-12-2012, 02:42 PM
  2. 1997 grand prix ventilation problem!
    By marwan in forum Canada
    Last Post: 10-24-2010, 10:38 AM
  3. 1997 Pontiac Grand Prix GT
    By LowRidinCrew in forum Off Topic Discussion
    Last Post: 12-27-2009, 07:31 PM
  4. 1997 Pontiac Grand prix SE
    By bizzy187 in forum Visual/Body Modifications
    Last Post: 05-14-2008, 11:25 AM
