Thread: Torque app knock gauge
Results 1 to 6 of 6
  1. #1 Torque app knock gauge
    Oct 2018
    TX
    Does the knock gauge on the torque pro app actually give accurate readings. Does anyone on the forum have good experiences with torque ?? Thank you
  2. #2 Re: Torque app knock gauge
    its 100% accurate. matches what both my dhp and hpt tuners scanners say.
  3. #3 Re: Torque app knock gauge
    Oct 2018
    TX
    So how can I tell what cylinder it's coming from. I run auto light 103's I'm assuming maybe it's time to change them. Mods zzp 10mm wires,3inch down pipe high flow cat res delete straight pipe back. 3.4 pulley 180 stat zzp 1.0 pcm zzp fender well intake. I seem to get 2 degrees of knock from time to time but usually when I don't run octane booster in my tank when I fill up.
  4. #4 Re: Torque app knock gauge
    I break stuff selliott's Avatar
    Kansas City
    So what octane fuel are you running?
  5. #5 Re: Torque app knock gauge
    theres no telling what cylinder its coming from. 103 are to cold for your mods. put some 104's in it gaped at 0.52
  6. #6 Re: Torque app knock gauge
    Oct 2018
    TX
    I always run 93 with an occasional octane booster. So 104s will be better as a hotter plug. Wouldn't that cause more knock? Also with the torque app it reads up to 35 degrees of timing at times. Which doesn't seem accurate at all. Thanks for all your help Scotty I'm just trying to keep that daily driver in pristine condition.
  1. Blue tooth Knock gauge questions
    By GTPNovak in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-22-2016, 10:31 PM
  2. Knock gauge installment help.
    By RyankendallGTP in forum Audio, Security & Visual Electronics
    Last Post: 10-23-2015, 04:16 PM
  3. Which torque app gauge is boost?
    By Jordan5066 in forum General Grand Prix Discussion
    Last Post: 12-08-2013, 12:27 AM
  4. How to use Torque Angle Gauge
    By dgiles79 in forum General Tech Discussion
    Last Post: 07-08-2010, 08:14 PM
  5. Plasti gauge/torque specs
    By speedemongtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-24-2009, 11:21 PM
