Thread: Gradual loss of power
Results 1 to 13 of 13
  1. #1 Gradual loss of power
    Donating Users gingerdude's Avatar
    Dec 2016
    IL
    Hey guys,
    My 01 GP SE with 62,000 miles has slowly lost power over time. For example at take off I can push the pedal down half way and it basically acts like I'm hardly pushing it. It just feels like it chugs up to 2,000 RPM, but once you get over that it feels completely normal. It doesn't sputter or slip, it's smooth acceleration.
    The power loss is evident on take off and on the highway no matter the gear. It literally feels like it has no balls anymore, but it has never tossed a code.
    Everything that you would normally replace on a vehicle as routine maintenance like fluids, filters, wires, plugs have been done within the last 30,000 miles. I've also already done heads and intakes. I am the only one who has done any level of maintenance to the vehicle except for the basic oil and tire stuff. I got the car at 34k from my grandpa who took worked for GM so he took care of it.
    I'm not going to be able to tackle the full tune up until September, so I'm hoping you all might have some advice on where to look.
    My thoughts are:
    1) Just needs a tune up. I put coppers in which were for 20k, yeah yeah I know, I don't have a garage anymore so it'll have to wait.
    2) Fuel pump dying or fuel restriction, same as 1.
    3) Clogged cat
    4) Transmission taking a crap
    01 GP SE 3.1
  2. #2 Re: Gradual loss of power
    i vote #3 meow. pull the up stream o2 out and run it, see if you gain some power back.
  3. #3 Re: Gradual loss of power
    GTX Level Member cheatah faheatah's Avatar
    May 2016
    Rouge Island
    X 2 on cat
    For the record : I am NOT a naked meth-head who shoves rocks up my butt.
  4. #4 Re: Gradual loss of power
    Dec 2016
    IL
    I had a feeling you all would say that. But better than the trans, so I'll give the O2 sensor removal a shot.
    If it is the cat it's going to be one hell of a time. When I did the heads and the intakes even my impact couldn't get the bolts out of the rear header. I ended up having to remove the rear header at the head and pulled the engine forward and the exhaust back as far as possible to work around it. Getting it back together was a huge b*tch.
    Thank God this car unbolts at the cat. I did exhaust on my 94 Grand Am and it was all one welded piece. I was under there hack sawing and cussing for hours.
    01 GP SE 3.1
  5. #5 Re: Gradual loss of power
    Dec 2016
    IL
    So question...
    If it is the catalytic converter I'm assuming I want to replace it sooner than later? If I leave it too long can I destroy the engine? I'm just trying to figure out how long I actually have because I have to basically bum garage space from others to work now and I don't have access to one currently.
    01 GP SE 3.1
  6. #6 Re: Gradual loss of power
    St. Louis
    Yep, I'd get on it. If it's clogged it will get to the point where the engine may not want to run well, if at all. Heck, I'd drop a ZZP 2.5" catted downpipe in it and call it a day. Get's rid of the U-bend and is stainless as well. Just throw some copper gasket sealer on the rear exhaust mani. end and a little on the pipe end and bolt it in.
    And soak down all the bolts/nuts with PB Blaster every day for a few days in advance. I'd bet those bolts will let go. I've actually taken the rear mani. bolts loose from up top with a long box wrench and some pipe on the end. Not sure if you can get to them like that on a 3.1L though.
  7. #7 Re: Gradual loss of power
    Dec 2016
    IL
    Okay so I'm not really sure it's actually the Cat. I took out the O2 sensor and noticed no difference.
    I realized that my loss in power is because it's misfiring in this RPM range... BAD. Like I'm talking 20+ misfires across all cylinders constantly on the scan tool only when between 2,000 and 3,000 RPM. If I accelerate slowly or very quickly as to not get into this range there are no misfires and it feels fine. And trust me I can definitely feel the misfires, they are unmistakeable. Weird part is that it does not misfire at all when in these RPM ranges in neutral.
    If you look at my post history it has always had a slight misfire at idle, but now it's worse as well.
    Also I noticed it tends to cycle the temperature up and down more often than normal. And KR is constant now.
    I was able to do plugs, air filter, and fuel filter where I am, but Cat isn't doable right now. Plugs are NGK Iridiums gapped at .060. I put premium in which nixed the KR for the most part, but amped up the misfires.
    Edit: Also given that it's misfiring this bad I'm likely forced to do the Cat anyways. But I don't want to toss a new Cat into a vehicle this is running this terribly. Would rather fix this first.
    01 GP SE 3.1
  8. #8 Re: Gradual loss of power
    GTP Level Member LeadfootCJ7's Avatar
    Oct 2012
    Houston, TX
    Have you replaced the fuel filter?
    2007 Grand Prix GXP;2002 Camaro Z28 - tune, CAI, and exhaust
    2006 GMC 2500HD - ATS high flow manifolds and uppipes, turbo back exhaust, blocked EGR, Denali headlights, Reflexxion Cown Hood
    1994 Olds Cutlass Supreme 2 door
  9. #9 Re: Gradual loss of power
    Dec 2016
    IL
    Yep. Plugs, air filter, fuel filter were done just last week. Problem is the same.
    01 GP SE 3.1
  10. #10 Re: Gradual loss of power
    Dec 2016
    IL
    I'm giving up. Taking it up to the dealership in a couple weeks to determine what's causing the misfire. I'll fix it myself, but I'll let them diagnose since I have replaced nearly everything since I have gotten the car. Then I'll toss the new cat on.
    01 GP SE 3.1
  11. #11 Re: Gradual loss of power
    Dec 2016
    IL
    Alright I replaced the Cat, O2 sensors, and the EGR valve. The EGR was a code that recently came up and I confirmed it wasn't sealing well. It runs MUCH better. Still has its usual misfire but at least it's drivable again.
    Let's see what the dealership can turn up on the misfire...
    01 GP SE 3.1
  12. #12 Re: Gradual loss of power
    Dec 2016
    IL
    They couldn't figure it out either.
    Lmao whatever. It runs well enough again. Thanks guys!
    01 GP SE 3.1
  13. #13 Re: Gradual loss of power
    Mar 2018
    NY
    I don't know if you ever resolved your misfire issue, but that unusual misfire could very likely be the beginning of intake gasket failure. The 3100's are prone to that as well. Just looking at the mileage and the age of your GP. The easiest way to tell is to spray brake cleaner around the intake manifold with it running. If the engine revs on its own there your issue. Also check your vacuum lines
  1. Power Loss
    By Stinkygrub in forum Engine
    Last Post: 07-20-2021, 09:11 PM
  2. loss of power in the cab
    By dewd in forum General Tech Discussion
    Last Post: 03-30-2014, 08:25 AM
  3. power loss
    By gtpsleeper in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-25-2011, 01:16 AM
  4. power loss
    By ChdMcD in forum General Tech Discussion
    Last Post: 04-15-2010, 02:57 PM
  5. power loss
    By offroadfury6 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-27-2008, 11:12 PM
