Thread: 08 power steering
Results 1 to 12 of 12
  1. #1 08 power steering
    GTP Level Member
    Oct 2014
    -5 this morning ano PS pump was whining pretty good. Checked the fluid and full of bubbles. Must be sucking air somewhere. To cold to look now. Any tips on making it last till summer?
  2. #2 Re: 08 power steering
    GTX Level Member wstefan20's Avatar
    Aug 2017
    Raytown, MO
    When's the last time you flushed the system? And if recently, did you use power steering fluid or trans fluid? A lot of people who try to get by with using trans fluid have this issue because it doesn't work well in the cold for our power steering systems (at least in my experience).
  3. #3 Re: 08 power steering
    did the wheels turn at all? did you drive it? thinking the fluid was really cold and thick, should warm up while driving.
  4. #4 Re: 08 power steering
    GTP Level Member
    Oct 2014
    Wheels turns and it drives. Just whines. Every other time i have had them whine they were low on fluid. So i would add some and it would quit. This time i checked while whining just after shut down and all bubbly.
    I have never flushed the system. 205K miles.
  5. #5 Re: 08 power steering
    so it never stopped the whine right? might be the pump taking a dump. a flush and some p/s medix stuff might help out.
    if you pull the return line off the bottom you can drain the pump fast and easy, its a rubber hose with a clip on it. you can get to it with the pass wheel removed.
  6. #6 Re: 08 power steering
    GTP Level Member
    Oct 2014
    It used to stop when warmed up or filled. I will know more tomorrow when i take it to work.
  7. #7 Re: 08 power steering
    Aug 2017
    Raytown, MO
    And no visible leaks or fluid going down?
  8. #8 Re: 08 power steering
    GTP Level Member
    Oct 2014
    There is probably a leak somewhere. But it leaks a Little oil also so haven’t been to worried. Nothing large volume. Probably should clean it up down there and monitor.
  9. #9 Re: 08 power steering
    GTP Level Member
    Oct 2014
    Put 150 miles on today. It quiets down when it warms up. When it warms up i will drain out the reservoir and refill and see that helps.
  10. #10 Re: 08 power steering
    GTP Level Member
    Oct 2014
    So i drained (sucked out) some fluid out of the resivoiur. And put some new stuff in and its a quieter can still hear it whine a bit and it definitely leaks somewhere but to cold to look at it any more.
    Do just the pumps go bad? Or how do you know if the rack is bad. Still steers the same.
  11. #11 Re: 08 power steering
    Donating User Odi's Avatar
    Chicago South Suburbs
    Whining pump with fluid = pump dying. It's not a hard replacement at all, just gotta take off the alternator.
  12. #12 Re: 08 power steering
    GTP Level Member
    Oct 2014
    Did the 02navyblue power steering flush and fill and added a bottle of lucus. Seems to be a-lot quieter but it is 40 also. Will see how it goes. Man some dirty stuff came out of there!!
  1. Replies: 3
    Last Post: 11-26-2014, 08:16 AM
  2. No power steering
    By 98buicksupercharged in forum Brakes/Suspension/Chassis
    Last Post: 02-05-2014, 04:20 PM
  3. power steering. feels like i have "half" the power
    By colindunn in forum General Tech Discussion
    Last Post: 07-23-2011, 09:15 AM
  4. Power steering
    By Pontiacman in forum Brakes/Suspension/Chassis
    Last Post: 08-01-2010, 07:46 AM
  5. power steering
    Last Post: 04-11-2009, 10:52 PM
