Thread: Surface rust on pinch welds
Results 1 to 10 of 10
  1. #1 Surface rust on pinch welds
    Donating Users gingerdude's Avatar
    Dec 2016
    IL
    So my car is pretty much in brand new condition. I have been using the pinch welds to lift the car for oil changes and such. Apparently that was a mistake because the paint chipped and has started to rust. I tossed some cheap black "rust stop" spray paint over it, but it didn't last very long before it chipped off. I have this issue on both sides of the car. I know how these rocker panels will rust out if not taken care of.
    I was thinking Eastwood Rust Converter covered by their Rust Encapsulator or Rubberized Rust Encapsulator Coating. At some point I may decide to do one of those rust inhibitor treatments to the entire car. Also frequent car washes.
    I know it's impossible to stop rust, but any better ideas on slowing this down? I'd like to get several years out of this car before it starts going to crap.
  2. #2 Re: Surface rust on pinch welds
    GTP Level Member
    Oct 2014
    We call that a new car in Minnesota.
  3. #3 Re: Surface rust on pinch welds
    Dec 2016
    IL
    Haha right. I'm in Chicago. First winter sitting outside and this. Now granted I did disturb the factory coat with the jack.
  4. #4 Re: Surface rust on pinch welds
    truly, thats not rust lol but i see your concern. you can por it or any other host of rust preventer, eliminators and sealers out there to pick from.
  5. #5 Re: Surface rust on pinch welds
    Nov 2012
    Madison
    then get a hockey puck for your jack to help a little
    And spray it every spring(when it's dry) with rustoleum.......everywhere.
  6. #6 Re: Surface rust on pinch welds
    Jan 2014
    AR
    You just need to prepare the metal better and spray paint will stick, and that will be fine. Sand until bright. Some 180-ish grit sandpaper then cleaning with alcohol or something. If you'd like to go an extra step for added peace of mind, use a rattle can etching primer before the paint. That will bite just a little better but yep lets face it... you'll want to squirt a little touch up there just about every time you jack it up. It sucks that jack points were not on the list of things to include when designing the car.
    FWIW, the legendary northern rocker rust starts on the inside, in an area not accessible with the rocker moldings in place (and those are easily damaged during R & I). The answer for prevention of that rust would be whats called internal panel coating or cavity wax, applied with a long wand. It fogs the inside of the structure with a wax / oil mixture that clings everywhere. Maybe a shop in your area could do that, perhaps without removing anything.
  7. #7 Re: Surface rust on pinch welds
    Dec 2016
    IL
    Alright. I also think I'll spring for one of those rust treatments. I was looking at this Corrosion Free service. I was curious if they did the rocker panels internally. Funnily enough their application demo video is the Grand Prix. It shows them getting into the rockers.
    https://corrosionfree.com/application-video/
  8. #8 Re: Surface rust on pinch welds
    Jan 2014
    AR
    Thats the right idea, I'm thinking. Although I don't live in the rust belt and don't know just how rip-off prone those places that rustproof stuff are. It would take a fairly long wand, like the three footer used with 3M Rust Fighter. Perhaps you can search up some rocker rust pics folks have posted here. I can think of a couple users who have some in their car's threads. Anyway, that would give you some insight as to where the rust actually begins, inside the structure.
    Using a one step rust converter on that jack point before sanding it could help. The back of the flange will need to be tended to as well.
  9. #9 Re: Surface rust on pinch welds
    Dec 2016
    IL
    I have been looking and to no avail, but is there a way to get into the inside of the rocker panels to spray rust inhibitor. In the video I provided they show lifting up the foot step plate in the door and access points, but mine definitely does not have a removable plate like that. It looks like there is no way to get inside that rocker easily.
  10. #10 Re: Surface rust on pinch welds
    Dec 2016
    IL
    Alright so I sanded as best as I could and applied Eastwood's Rust Encapsulator and top coated with Rustoleum paint (found some very close to the color of my car). It looks pretty solid. It's been several weeks. Going to get the Corrosion free treatment when it gets a little warmer.
    Still can't find access into those rockers from the outside or inside. Apparently some of the older GPs had foot plates inside the door you could remove. Mine just has what appears to be a sticker. I called the place and they said they could do it for like $170, but that they may have to drill holes in those rockers on the inside to get to them. Everywhere else they can get to without holes. Any thoughts?
  1. What do you guys think about clamps vs welds
    By lcloveiii in forum Introductions/Noob Questions
    Last Post: 03-07-2016, 05:06 PM
  2. Rusted pinch weld remove rack and pinion?
    By jj5428 in forum General Grand Prix Discussion
    Last Post: 06-26-2013, 09:14 PM
  3. Exercise - push, squeeze, pinch and let drop
    Last Post: 05-17-2013, 11:50 AM
  4. surface rust
    By Lacboi in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-07-2011, 08:58 AM
