Thread: P1125 and P2138
Results 1 to 2 of 2
  1. #1 P1125 and P2138
    Dec 2021
    Michigan
    Hey all!
    I have a 2006 GP GT with the L32 supercharged motor with an intermittent issue that throws both P1125 (accelerator pedal sensor fault) and P2138 (Throttle/Pedal Pos Sensor/Switch D / E Voltage Correlation) and throws the car into limp mode. I've looked at most of the wiring pertaining to this circuit, just havent had the time to really get up under the dash and inspect everything. Underhood wiring looks good, no shorts there, throttle body opens and closes smoothly and freely. Has anybody had this issue before? I've done some digging around on forums and found that this can be a pretty challenging issue to solve if it isnt simply the accelerator pedal sensor going bad.
    If you've had experience with this before, what did you do?
  2. #2 Re: P1125 and P2138
    St. Louis
    Might want to post this in the V6 Supercharged section, but here's what I've found. The second link would be where I would start besides checking your grounds.
    Might be a bad ground from the pedal at the TB
    2004 gt accelerator position problem with codes p1125, p2120, p2138
    P1125 and P2138, replaced pedal won't go away
  1. P1125 and P2138, replaced pedal won't go away
    By Metal Links in forum General Tech Discussion
    Last Post: 07-29-2017, 07:12 PM
  2. 2004 gt accelerator position problem with codes p1125, p2120, p2138
    By 2004 GT GIRL in forum General Grand Prix Discussion
    Last Post: 09-30-2016, 03:15 PM
  3. Replies: 0
    Last Post: 05-17-2015, 10:47 PM
  4. 2008Grand prix fault codes p1125-p2120-p2138
    By daviddawg in forum Introductions/Noob Questions
    Last Post: 04-04-2014, 02:10 PM
  5. P2138 P1125 codes
    By jlusleton in forum General Tech Discussion
    Last Post: 09-23-2011, 05:35 PM
