Thread: P-steering rack rebuild
Results 1 to 13 of 13
  1. #1 P-steering rack rebuild
    Jul 2015
    Kansas
    Has anyone done a rebuild on a P-steering rack. I have an 01 Grand prix that the rack is leaking like a sieve. Thinking about a rebuild kit.
  2. #2 Re: P-steering rack rebuild
    May 2012
    Where winter never ends
    Common, just go buy a new one/reman from the store. Easier.
    2000 Regal - Winter Beater
  3. #3 Re: P-steering rack rebuild
    X2, buy new one, swap it.
  4. #4 Re: P-steering rack rebuild
    Jul 2015
    Kansas
    sounds like a re-man then...thanks all
  5. #5 Re: P-steering rack rebuild
    St. Louis
    Don't forget to check if you have Magansteer or not. If you look down at the rack where it connects to the steering and see an electrical plug coming from the rack to a plug on top of the trans near the shift cable then you have Magnasteer. I think the RPO code if you look on the trunk sticker is NV7.
  6. #6 Re: P-steering rack rebuild
    Ive done Cardone racks from Oreillys twice. Take the rack out 1st then bring it in and get the new one, IIRC the damn core charge costs nearly as much as the part does!
    Edit twice as in 2 different cars. Ive had 7 wbodies...........
    Not 2 in the same car or I wouldn't recommend cardone parts LOL!
  7. #7 Re: P-steering rack rebuild
    Jul 2015
    Kansas
    Thanks for the info guys! I didn't even know MagnaSteer was even an option on these cars!
    @MyNameBlows -- 7!! now that's dedication!!!
    I will probably get it at AutoZone, lifetime warranty and it's very close.
  8. #8 Re: P-steering rack rebuild
    try advace auto on line, add a discount code for cash off, then pick up local in 30 minutes.
  9. #9 Re: P-steering rack rebuild
    GT Level Member mkyota1's Avatar
    Daytona, florida
    I have had really bad luck with all of the rebuilt racks i have installed. They usually end up leaking in a year or two. I recommend getting a used OE rack and install it. Im most cases it will last longer and most likely be cheaper.
    R.I.P.-----99 black GTX 12.9@107
    97 gp gt turbo--- Hx35, xp cam, 130#, double roller, hv3, l67 block, 42.5#, crap tune by me+ Dhp, devils own injection
    300m, 7/8" 2.93 11.78@118
  10. #10 Re: P-steering rack rebuild
    GT Level Member JamesIvey24's Avatar
    May 2011
    Illinois
    let me spell rebuild for you. rock-auto.com
  11. #11 Re: P-steering rack rebuild
    You think he's dedicated with 7 cars... I've had 7 Regals.. Plus 2 Bonnie's, a Grand Prix and a Park Ave
  12. #12 Re: P-steering rack rebuild
    Jul 2015
    Kansas
    And here I thought I was good with a Grand Prix and two Bonnies! I am WAY behind!
  13. #13 Re: P-steering rack rebuild
    Jul 2015
    Kansas
    Thanks everyone...I feel both relieved and stupid. Relieved that I don't have to put a new rack in, and stupid that I boneheaded getting the pressure line on the power steering pump tightened all the way. It's fixed now though!
  1. Steering Rack
    By kissmyss in forum Brakes/Suspension/Chassis
    Last Post: 07-20-2015, 07:03 AM
  2. Steering rack replacement.
    By jmdc692 in forum General W body
    Last Post: 07-25-2014, 10:27 AM
  3. How can you tell steering rack bad?
    By timboku in forum Brakes/Suspension/Chassis
    Last Post: 03-31-2014, 12:14 AM
  4. Steering rack
    By 98ctd in forum Brakes/Suspension/Chassis
    Last Post: 01-21-2014, 10:59 AM
  5. steering rack
    By GTP Ryan in forum General Tech Discussion
    Last Post: 11-22-2010, 04:04 PM
