Thread: Ls7 lifters
Results 1 to 6 of 6
  1. #1 Ls7 lifters
    SE Level Member gbgn1's Avatar
    Dec 2012
    TX
    Running a stage 2 turbo cam from intense. how important is running ls7 lifters over stock? stock rockers as of right now.
  2. #2 Re: Ls7 lifters
    Kemmerer, Wyoming
    not running LS7 lifters is taking away quite a bit of hp, the stock lifters are pathetic in comparison.
  3. #3 Re: Ls7 lifters
    Lifters add hp?
    wut?
  4. #4 Re: Ls7 lifters
    Kemmerer, Wyoming
    lifters dont add hp, but not running a good lifter won't support as much hp, the whole rpm dip at 5600 rpm with the stock lifter isn't going to make the most power.
  5. #5 Re: Ls7 lifters
    Say wht
    Unless you need to replace your current lifters (ls7 are our replacement) then stick with the stockers
    04 Comp G.
  6. #6 Re: Ls7 lifters
    Dec 2012
    TX
    Thanks, thats what I was thinking. Im thinking they will be fine
  1. Lifters
    By 2000 Black 2dr in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-09-2010, 01:12 PM
  2. Which lifters to buy?
    By BDEGhost in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-01-2010, 06:17 PM
  3. Bad lifters?
    By rah575554eg in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-01-2010, 07:59 AM
  4. Bad Lifters?
    By BDEGhost in forum General Tech Discussion
    Last Post: 11-04-2009, 07:46 PM
