Thread: Comp g head stumper
Results 1 to 9 of 9
  1. #1 Comp g head stumper
    Jan 2013
    East Providence
    Hey guys, long time gtp fanatic and I really need help, I dont know where else to turn. I bought an 04 comp g that stalls after startup, and used to hesitate under heavy load, had the original plugs. A fresh set of delco 41-101 plugs, stock gap, replacement delco wires and it ran a little better. Fuel trims are spot on, pump has nearly 60psi, removed the icm to check for any corrosion and found quite a bit. I cleaned all of it, Still has a random misfire as seen on a scantool, when the car is cold it bogs,the throttle randomly feels like it completely cuts out and I have to nearly floor it to get it to climb hills. It gets better as it warms up, either the car or outside. The best part, it gets me about 8mpg or LESS on my morning commute and struggles to maintain any reasonable highway speed. No codes whatsoever, I'm at my wits end with it and hope you guys can point me in the right direction. Any help at all would be appreciated!
  2. #2 Re: Comp g head stumper
    unplug the maf, then fire it up, see if it runs better like that.
  3. #3 Re: Comp g head stumper
    Jan 2013
    East Providence
    Maf is brand new, the older one ran the exact same way, I changed it because the crappy housing was cracked
  4. #4 Re: Comp g head stumper
    what brand maf? after market maf's suck. if thats what you got, unplug it. fire it up.
  5. #5 Re: Comp g head stumper
    Awesome Level Member chrsmi1's Avatar
    Jan 2013
    Raleigh, NC
    Make a list and go through it. There are only so many things that can cause the symptoms you described. Start with Scott's suggestion and unplug your maf to determine if thats it. If no change, go from there. Spark (coils, Icm, Plugs) Fuel (filter, Pressure, injectors,) and Air (throttle body, filter,).
    I know you said you checked your ICM but that could be it. Random misfires after changing plugs, corrosion makes me think that. I would swing by a junkyard and grab another to see.
    Comp G. E85, 2.8, Headers, Tune, Intake, S1X, 105# springs, 60 # injectors, 255 walbro,etc.
    *NEW* 2002 Camaro Z28- Lid, Headers, Catback
  6. #6 Re: Comp g head stumper
    Jan 2013
    East Providence
    MAF is the OEM delco unit, Im wondering if its the icm myself, I also keep hearing about crank sensors. But would a crank sensor cause ****ty misfires, stalling and rough running with temp change? I thought that'd just be stalling,
  7. #7 Re: Comp g head stumper
    SWPA
    Stalling after startup is probably the TB needing cleaned.
  8. #8 Re: Comp g head stumper
    ive had the icm to crank harness fail on me. that gave me some codes finally tho, 2 icm codes, and later a crank sensor code.
  9. #9 Re: Comp g head stumper
    Buffalo
    Never mind
  1. Replies: 8
    Last Post: 08-20-2015, 07:52 AM
  2. WTB: ARP Head Studs & Head Gaskets, FelPro or Multi Layer
    By JordanGT in forum Wanted To Buy - Parts
    Last Post: 03-05-2015, 12:51 AM
  3. New head unit in my 04 Comp G
    By jbelectronic in forum Audio, Security & Visual Electronics
    Last Post: 03-09-2013, 11:30 PM
  4. Power window stumper
    By pbrumfield2007 in forum Introductions/Noob Questions
    Last Post: 08-12-2009, 11:25 AM
