Thread: Nasty Plugs Look!
Page 1 of 10 123 ... LastLast
Results 1 to 20 of 191
  1. #1 Nasty Plugs Look!
    Oct 2014
    portland oregon
    My car runs terrible and its ran rich since I bought it (when it runs lol). I decided to look at the plugs and this is what they look like. They smell like gas and there is oil up into the threads. I would like your feed back on how to remedy this also what the cause could be and how to lean it out.
    I bought a scanner and ran some test 2 out of 3 failed but i dont know what the test is or what they mean Lol sorry im not very good at these things. Scanner states
    Test 4
    MOD : $10
    MEAS : 8002
    MAX : 4D7
    MIN :----
    STS :FAIL
    Test 7
    MOD : $10
    MEAS: FFD3
    MAX :0
    MIN :----
    STS :FAIL
    Bunch of jiberish to me. Last but not least i Got a P0134 code this one mean my o2 sensor has died? If so what are your thoughts on a o2 emulator? I seen on zzp for 50 bucks I just dont know if its worth the money. As i learn this car ill have alot of questions i bought it as a project and i knew it was going to be a challenge. Thank you in advance
  2. #2 Re: Nasty Plugs Look!
    that code says no activity, so your fuse blew in the fuse box #21 iirc. or the o2 harness got melted. or both.
  3. #3 Re: Nasty Plugs Look!
    Oct 2014
    portland oregon
    thanks for responding Scottydog. I checked the fuse its good. wires and connection are good. Under car they are behind heat shield in engine bay they are routed away from header down pipes and in a insulated heat shield. Are you able to decipher the scan tests? And or stinky lightly moist plugs?
  4. #4 Re: Nasty Plugs Look!
    the o2 code is causing the over fueling i bet. what they do when they dont work.
    id double check them wires. wire loom can melt too. or the o2 is just flat out dead.
    did you use a zzp type extension? or make your own?
  5. #5 Re: Nasty Plugs Look!
    If that scanner has live data, just view the o2 volts.
    It's either stuck at .800mv or above or steady at 400-600mv, thus it's dead and not switching.
  6. #6 Re: Nasty Plugs Look!
    Oct 2014
    portland oregon
    I pulled the insulated loom off and the wires are all good. Im not sure on the extenstion i bought the car as it is. I put head lights and tail lights in it and replaced a few things but thats its. There has been a bunch of things done to it perhaps quality of upgrades were poor. If i can get the car to run long enough ill check those numbers. I viewed some graphs when it was running I had no idea what they ment but they were jumping all over the place but the idle was pretty smooth. I thought the scanner would help me figure things out but it has a bunch of codes that are all greek to me. Thanks for your imput
  7. #7 Re: Nasty Plugs Look!
    buy a new ac delco o2 sensor then. rockauto sells them much cheaper then the local parts stores.
  8. #8 Re: Nasty Plugs Look!
    Oct 2014
    portland oregon
    ok ill buy one.. any idea ball park price? What about the failed scanner test?
  9. #9 Re: Nasty Plugs Look!
    o2 should dance up and down fast on the scan. if its slow or not moving at all the o2 is bad.
    mine for a 98 was like 40 bucks. they sell in that price range. you want bank one up stream o2.
  10. #10 Re: Nasty Plugs Look!
    Oct 2014
    portland oregon
    bank 1 upstream o2 got it ty. Also i have no cat or down pipe. my headers go to a collector that my o2 bung is welded into then a flex pipe to the resonator. could the lack of a cat mess up the o2 sensor?
  11. #11 Re: Nasty Plugs Look!
    no cat only messes with the post cat o2 aka the one under the car just before the cat back.
    what year is your car?
  12. #12 Re: Nasty Plugs Look!
    Oct 2014
    portland oregon
    a 97 I think its just the one O2 I wasnt aware of another
  13. #13 Re: Nasty Plugs Look!
    they all have two. ones in the lower header. the other is right before the flange to the cat back. if you dont have one, its been tuned out already.
  14. #14 Re: Nasty Plugs Look!
    Oct 2014
    portland oregon
    ill seach for another. If none do i want bank 1 downstream?
  15. #15 Re: Nasty Plugs Look!
    bank one up stream is what you need.
  16. #16 Re: Nasty Plugs Look!
    Oct 2014
    portland oregon
    Yep just 1 o2 the front header runs over the trans down to the collector the backs run strait to the collector no bungs welded in anywhere no egr either. the egr is there and plugged in but the tubes are just open and the header is welded closed and the intake has a plug in it
  17. #17 Re: Nasty Plugs Look!
    ok, you've been tuned then. or you'd have codes for the rear o2 and egr.
  18. #18 Re: Nasty Plugs Look!
    Oct 2014
    portland oregon
    the car has a intense racing pcm and it did throw a egr code once i erased it and it didnt come back..yet
  19. #19 Re: Nasty Plugs Look!
    Oct 2014
    portland oregon
    new o2 sensor is on its way should be here by friday
  20. #20 Re: Nasty Plugs Look!
    Oct 2014
    portland oregon
    does the balancer really need to come off to change the CPS or is there another way?
  1. Nasty gunk all over...
    By WarStryker13 in forum General Grand Prix Discussion
    Last Post: 11-05-2014, 11:45 AM
  2. Nasty Rumble
    By KitRae in forum Engine
    Last Post: 11-15-2012, 08:33 AM
  3. nasty s4, mazdaspeed 3, and gti
    By 99prixgt in forum Track Sessions and Kills
    Last Post: 12-17-2009, 01:13 AM
