Thread: Horn not working
Results 1 to 6 of 6
  1. #1 Horn not working
    GTP Level Member 04lss's Avatar
    Sep 2014
    Richmond Virginia
    So i need to get my GTP inspected and im rolling through the list, and my horn doesnt work,
    where is it on these cars? any simple things i should check for before replacing it?
  2. #2 Re: Horn not working
    GTP Level Member bonerjamz03's Avatar
    Apr 2009
    Upper Darby, PA
    I think it's in the passenger side front bumper by the fog light. Check fuses and wires first
  3. #3 Re: Horn not working
    GTP Level Member
    Apr 2012
    Las Vegas, Nv
    There is a fuse and a relay in the under hood fuse box.
  4. #4 Re: Horn not working
    Jan 2014
    AR
    If the horns have been replaced, its possible to install them wrong (opening facing up) and have them get full of water. Also if replaced, some replacements have sketchy wiring between the horns. Also if any work has ever been done in the steering column and you don't have juice at the horn or signal at the relay... theres a delicate conection between the airbag and clockspring... a tiny lug on a black plastic tube can easily be broken and you end up with no horn. Just throwing out a couple scenarios to be aware of as you hunt for the trouble.
  5. #5 Re: Horn not working
    Sep 2014
    Richmond Virginia
    Looked in the fuse panel, no fuse in the spot, works fine
  6. #6 Re: Horn not working
    Jul 2010
    Coquitlam,BC,Canada
    Quote Originally Posted by 04lss View Post
    Are you saying there is no fuse where the horn fuse should be?
    97-03 horns are right front.....
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  1. 2002 Grand Prix Horn Not Working
    By RustyHorse in forum General Grand Prix Discussion
    Last Post: 06-08-2015, 09:43 AM
  2. Cruise & Horn not working
    By chuckbattams in forum Audio, Security & Visual Electronics
    Last Post: 08-26-2013, 05:32 AM
  3. no horn
    By waltvmac in forum General Tech Discussion
    Last Post: 04-10-2011, 07:25 PM
  4. Horn not working.
    By mntnbiker in forum General Tech Discussion
    Last Post: 12-07-2009, 01:06 PM
  5. Horn Going off
    By Bruteforce72 in forum General Tech Discussion
    Last Post: 01-12-2009, 01:47 PM
