Thread: Turn signals....
Results 1 to 7 of 7
  1. #1 Turn signals....
    Sep 2015
    Michigan
    This is my problem... Front turn signals light but will not blink stay on all the time. Rear seem to work fine. Dash goes into hyper mode. I'm thinking ground on the fronts. I would think if it were the flasher relay none of the turn signals would be working. Forgive me if this is a beat up issue. I searched and wasn't able to find my same problem. Thanks for any advise.
  2. #2 Re: Turn signals....
    check the bulb yet? its got two filaments inside it. when the dash light goes hyper thats your sign of a blown bulb 99% or the time.
  3. #3 Re: Turn signals....
    Sep 2015
    Michigan
    I replaced both front bulbs. Just odd that it the two front turn signals. How ever I'm going back to check them again. Hopeing that is the fix don't feel like chasing wires today. Thanks for the reply.
  4. #4 Re: Turn signals....
    the sockets also go bad. mine did.
  5. #5 Re: Turn signals....
    Sep 2015
    Michigan
    Scottydoggs, Thank you. One of the new bulbs was missing the conection wire. Thanks again.
  6. #6 Re: Turn signals....
    look inside the socket for it to be broken. theres a thick wire part that breaks, then it breaks the wire on the bulb. its what makes the connection to the bulb.
  7. #7 Re: Turn signals....
    SE Level Member NecroTek's Avatar
    Sep 2015
    Arizona
    I had the same issue. Took it in, had the whole blinker arm assembly replaced and a relay.
    Blinkers are now normal.
  1. Turn signals
    By Madness in forum Audio, Security & Visual Electronics
    Last Post: 03-07-2015, 11:45 PM
  2. Has anyone modified combination stop/turn/tail lights to independent turn signals?
    By April Thompson in forum Visual/Body Modifications
    Last Post: 03-02-2015, 08:22 PM
  3. High beams turn on intermittently when using turn signals
    By Boomersooner in forum General Tech Discussion
    Last Post: 01-13-2012, 08:31 PM
  4. turn signals
    By echarleswhyte in forum The Rant Forum
    Last Post: 12-07-2009, 09:49 PM
  5. Turn Signals
    By brett88 in forum General Tech Discussion
    Last Post: 10-03-2009, 07:21 PM
