Thread: Well this sucks
Results 1 to 15 of 15
  1. #1 Well this sucks
    USA
    So I was driving along and I notice my temp gauge shoot up out of nowhere. So I pulled over and there is coolant leaking and a strong odor of burning coolant. In the picture you can see (hopefully) a hole that shouldn't be there. What in the world would cause this?
    Well this sucks Attached Images
    Stattama T67 Turbo, A2A IC, SLP Cat Back Exhaust, Oversized ZZP radiator, ZZP 1" Transmisson chain, PRJ Ignition Wires, MSD Ignition Coils, Inferno Ram Air Hood, Powerslot Brake Rotors and Pads, 18" American Racing Muscel Phanton, HP Tuner
  2. #2 Re: Well this sucks
    Mar 2012
    NC
    Coolant elbows. Like $6 at the parts store.
  3. #3 Re: Well this sucks
    GTP Level Member Impala131's Avatar
    Knoxville, TN
    Quote Originally Posted by Sven The Moparman View Post
    Spend the extra couple bucks and get the aluminum, not the plastic, elbows.
    2003 Grand Prix GTP.... the journey begins again....
    E85 Self Tune with HPT, 80# Injectors, Gen V 3.4 pulley, SD Headers, AL605 Plugs
  4. #4 Re: Well this sucks
    Extremely common issue aswell.
  5. #5 Re: Well this sucks
    USA
    Would a broken coolant elbow cause the service brake system light to appear?
  6. #6 Re: Well this sucks
    hangover park IL
    Quote Originally Posted by 04trbogp View Post
    engine overheating puts the pcm into a save the day mode, changing shift points, alternator turn on, fans etc. so yes it could be a byproduct especially if the pcm killed the alternator field and charging voltage dropped the abs/trac/etc would be shutdown.
    it could be independently triggered from a brake system fault, but so many things are interconnected on these nowadays id suggest fixing the coolant elbows and retesting
    ~James~ Psychotic Gearhead
  7. #7 Re: Well this sucks
    USA
    I replaced the coolant elbows and added coolant, now the car won't start. My battery is brand new and all the electrical comes on inside. Needs a jump? Alternator?
  8. #8 Re: Well this sucks
    Mar 2012
    NC
    Does it crank or just do nothing?
  9. #9 Re: Well this sucks
    USA
    Nothing, electrical comes on....that's about it.
  10. #10 Re: Well this sucks
    Donating Users EHB's Avatar
    Dec 2014
    Maryland
    did you strip the terminal threads when you connected the battery ? i'm assuming you disconnected the battery when you move the alternator out of the way.
    2000 GTP - 3" Catted DP...ZZP Plog...9" Cone filter...Reptile pcm...3.4 pulley...AL104's
  11. #11 Re: Well this sucks
    Who is this guy? SubwayGuy's Avatar
    Apr 2015
    Unlikely possibility, but try hitting the starter.
  12. #12 Re: Well this sucks
    USA
    Battery was disconnected but threads look good. Whats weird is I just filled it with fuel too and now its say its empty, can it be that simple? The fuel didn't leak out anywhere. Usually even with no fuel the car will crank. Fuel pump? Maybe pass lock? Blown fuse?
  13. #13 Re: Well this sucks
    Voltage, fuel, spark you need to
    Figure out which one is missing
    04 Comp G.
  14. #14 Re: Well this sucks
    Enfield, CT
    I'm thinking you forgot to hook something electrical back up..
    Sent from my LG G3
  15. #15 Re: Well this sucks
    USA
    Quote Originally Posted by HighOctaneRacing View Post
    Sent from my LG G3
    I can't find anything not hooked up. I am really baffled as to what it is.
  1. Well this sucks. What would you do?
    By DBGP in forum The Rant Forum
    Last Post: 01-31-2012, 05:02 AM
  2. this sucks
    By ammojunkie in forum General Tech Discussion
    Last Post: 12-30-2009, 05:39 PM
  3. wow this sucks
    By Will5600 in forum General Tech Discussion
    Last Post: 11-23-2009, 07:23 PM
  4. ZZP (sucks)
    By 98GTPCALGARY in forum The Rant Forum
    Last Post: 04-08-2009, 07:24 AM
  5. Having the flu sucks!!!
    Last Post: 12-18-2008, 04:34 PM
