Thread: What brand CAT is best? Should I go high-flow?
Results 1 to 12 of 12
  1. #1 What brand CAT is best? Should I go high-flow?
    SE Level Member Blacknight02GT's Avatar
    Feb 2009
    Buffalo,NY
    So, recently my stock cat converter clogged ( I believe there was an extended service bulletin on 01-02's but mine is well past 10 years old now) and I had to gut it and weld it back on "for now"; but I live in NY and need it fixed ASAP to pass emissions inspection. Is this a good excuse to go the performance route with a bigger downpipe and high flow cat? Or should I go with a stock type replacement? I dont want to have to worry about CEL's and looking for the best fitment, quality build, and easy installation option. Thoughts?
    2002 Grand Prix GT (K&N + Ram Air = BEAST)
  2. #2 Re: What brand CAT is best? Should I go high-flow?
    Awesome Level Member chrsmi1's Avatar
    Jan 2013
    Raleigh, NC
    http://www.amazon.com/Magnaflow-5995...ytic+converter
    And if you can afford the extra $200, buy some speed daddy headers. They Go great together.
    Comp G. E85, 2.8, Headers, Tune, Intake, S1X, 105# springs, 60 # injectors, 255 walbro,etc.
    *NEW* 2002 Camaro Z28- Lid, Headers, Catback
  3. #3 Re: What brand CAT is best? Should I go high-flow?
    ny is carb compliant now from what i hear. aka same dumb rules as CA.
  4. #4 Re: What brand CAT is best? Should I go high-flow?
    Jan 2013
    Raleigh, NC
    Quote Originally Posted by ScottyDoggs View Post
    boooooooooooo!
    Move out of NY OP!
  5. #5 Re: What brand CAT is best? Should I go high-flow?
    i got a cat like this on my speed daddy headers. http://www.ebay.com/itm/3-Thunderbol...item20d0c877ba
    but i also have my cat and rear o2 deleted in the pcm.
  6. #6 Re: What brand CAT is best? Should I go high-flow?
    Jan 2014
    AR
    For a fast and sure fit with no hassle, I'd get a salvage downpipe assembly if available. And new gaskets. Be prepared for broken bolts at the cat-back flange (have drill and extra bolt / nut handy). Go soak the flanges in penetrating oil now and give yourself a sporting chance of not breaking!
  7. #7 Re: What brand CAT is best? Should I go high-flow?
    Sep 2014
    Worcester, MA
    FYI a catalytic converter heats up to do its job, and depends on a certain amount of exhaust flow to get hot enough to react.
    If you use an oversize catalytic converter, it may never get hot enough and won't control emissions and could eventually clog because it's not "burning" off the residual HC's. A converter that's too small could also get too hot, but I don't know anyone who is going to try to put an undersized converter.
    Be prudent in selection of any non-OEM catalytic converter if you have to pass emissions (and can't just disable the rear O2).
  8. #8 Re: What brand CAT is best? Should I go high-flow?
    Feb 2009
    Buffalo,NY
    Anyone ever use this Eastern Catalytic converter?
    http://www.rockauto.com/catalog/more...nid=428&jpid=2
    Seems to be one of the closest to stock I can find for aftermarket. Ideally, I'd like to get the set up with the best performance; but also have it not throw a code. I realize this is a fine line and it seems high-flow is impossible to guarantee. Another question: will most of these aftermarket products such as the eastern listed above eliminated the stock "U bend"? It's hard to tell from the photos; but I'm also no exahust expert so i'm not 100% on what I'm looking at.
    5 If so, would this improve performance simply by removing that constriction?
  9. #9 Re: What brand CAT is best? Should I go high-flow?
    Feb 2009
    Buffalo,NY
    Quote Originally Posted by idrivejunk View Post
    I'm already planning on putting new bolts and nuts on that; mine is pretty rotted away...
  10. #10 Re: What brand CAT is best? Should I go high-flow?
    Feb 2009
    Buffalo,NY
    Do you guys recommend replacing the O2 sensors too when replacing a cat? nothing appears to be wrong with mine; but they are almost 14 years old
  11. #11 Re: What brand CAT is best? Should I go high-flow?
    Jan 2014
    AR
    I'd swap it over. Only the rear one is on the DP.
  12. #12 Re: What brand CAT is best? Should I go high-flow?
    Donating Users EHB's Avatar
    Dec 2014
    Maryland
    you should replace them both. a bad O2 sensor doesn't always tell you it's bad by throwing a code. they can be the cause of lost fuel mileage. only buy acdelco sensors. amazon is as cheap as anywhere to get them.
    2000 GTP - 3" Catted DP...ZZP Plog...9" Cone filter...Reptile pcm...3.4 pulley...AL104's
