Thread: 2005 GXP traction/stability fault.. good abs scanner?
Results 1 to 4 of 4
  1. #1 2005 GXP traction/stability fault.. good abs scanner?
    GT Level Member chicagochuck's Avatar
    Aug 2012
    Chicago
    I have a 2005 v8 gxp 75,000 miles and it has the traction and stability lights on. I checked the hub bearings and sensors, I didn't see anything unplugged or broken but of course most of the time its the wiring so I have read. I know prob comes up a lot...
    I also I have a 2000 3.8 supercharged 178,000 miles, Buick regal with a P0440 code.. I changed the gas cap with oem, but it didn't help.
    So I was wondering if its a scanner abs , evap test...etc that could probably help me with both of these problems before I spend 200 or more on diagnostic tests from a shop. So I was thinking why not buy a scanner myself. I have a basic obd scanner for engine codes with ready monitors, but it cant read abs, srs or test for evap leaks etc. I don't think I repair enough cars to justify a very pricey scanner right now.
    Any suggestions on good scanners? I came across a few links below....Thanks
    http://www.ebay.com/itm/GM-GENERAL-M...161780&vxp=mtr
    or
    http://www.harborfreight.com/can-obd...ck-to-top-link
  2. #2 Re: 2005 GXP traction/stability fault.. good abs scanner?
    Donating Users timboku's Avatar
    Montgomery, IL
    Your gxp is more than likely a bad wheel bearing,..my 05 went through 2 sets of fronts and replaced under warranty in 100k
    2002 GTP..DD.. Topswapped Gen V L26, XP cam, Full Size IC, E85, 2.6 Pulley,SD Headers, K&N Intake, N*/Lq4,FP Rewire, TEP Trans, F body Fronts, GXP Rear Brakes, LE Spoiler, AGXs with vogtland springs, bonni gxp rims, Timboku Tuned
    1995 Cutlass Supreme Convertible...Soon to be L32Swapped.....2005 GXP Stock
  3. #3 Re: 2005 GXP traction/stability fault.. good abs scanner?
    Aug 2012
    Chicago
    Yea that's what I'm thinking but no clue in which one it is.
  4. #4 Re: 2005 GXP traction/stability fault.. good abs scanner?
    GTP Level Member Impala131's Avatar
    Knoxville, TN
    I've found a solution that will allow you to scan for ABS codes for about $25.... the method of acquiring it may be against forum rules to post, just PM me and I'll give you the details.
    2003 Grand Prix GTP.... the journey begins again....
    E85 Self Tune with HPT, 80# Injectors, Gen V 3.4 pulley, SD Headers, AL605 Plugs
  1. 2004 gtp comp g abs/stability/traction light
    By Gohan77 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-20-2021, 05:11 AM
  2. Service ABS/Stability/Traction/Brake System
    By Perma in forum General Grand Prix Discussion
    Last Post: 06-01-2015, 06:38 PM
  3. Grand Prix GXP ABS, Traction, Stability control malfunction.
    By onebadcaballero in forum General Tech Discussion
    Last Post: 10-29-2014, 04:01 PM
  4. Traction Control/Stability System Module
    By teamfbody in forum Brakes/Suspension/Chassis
    Last Post: 06-18-2012, 07:16 PM
  5. abs/traction/stability service lights
    By jackster1234 in forum General Tech Discussion
    Last Post: 11-09-2010, 01:01 AM
