Thread: My vents are stuck on floor.
Results 1 to 6 of 6
  1. #1 My vents are stuck on floor.
    Aug 2015
    McKeesport, PA
    I have 98 Grandprix GT. my rents are stuck on floor. I have the climate temp control with CJ2 system. I just changed the blend door actuators, checked the connector to see if it was getting power, Still no good . Please help. I'm so lost.
  2. #2 Re: My vents are stuck on floor.
    theres a hard vac line pass side fire wall to the back of your intake. where the brake booster hose goes.
    make sure its hooked up and not broken.
  3. #3 Re: My vents are stuck on floor.
    Aug 2015
    McKeesport, PA
    Just ran a new vacuum line. Still no good.
  4. #4 Re: My vents are stuck on floor.
    ran the line to where? it goes down the pass side fender under the fuse box and into the fat wire harness and into the car, then to a box, that box goes bad, the climate control unit can fail too. some cars have a vac ball in the d/s fender, under the fuse box is a T on some cars, then the other end of the T goes to the vac ball.
    the air flow direction is controlled by the vac line. in the dash are two air diaphragm deals that move the linkage, this linkage breaks too.
  5. #5 Re: My vents are stuck on floor.
    Aug 2015
    McKeesport, PA
    I checked the vac line. It has suction . To the box. I have an electric vacuum solenoid . I took my glove box off, and checked around there, checked a vac line that went to this canister looking thing. I didn't feel too much suction, maybe even no suction at all. .
  6. #6 Re: My vents are stuck on floor.
    that line on the round thing leads back to that box under the dash. try car running, change the flow. see if it sucks more or less.
    theres one on the other side too. iirc that one controls the floor. seen 2 cars here stuck on floor and defrost and both were the linkage broke on the drover side.
    a few others were that box in the dash, and one other was the climate control unit itself.
    and a huge bunch with just a busted off vac line off the engine.
    those are all the common issues.
  1. Air Conditioning blows through vents and then to floor.
    By 74NovaCustom in forum General Tech Discussion
    Last Post: 08-26-2019, 09:08 PM
  2. A/C/Heat air blows ONLY from defrost vents and floor
    By Ridin ON Chrome in forum General Tech Discussion
    Last Post: 07-27-2015, 09:47 AM
  3. Replies: 1
    Last Post: 03-08-2012, 01:07 PM
  4. 98 gtp w/ DCC will blow on defrost or vents but not floor-please help
    By Liquifire in forum General Tech Discussion
    Last Post: 08-03-2011, 06:07 PM
  5. Front Dash & Floor Air Vents Blocked!
    By marwan in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-20-2010, 11:00 PM
