Thread: fuse box fire 06' GT
Results 1 to 9 of 9
  1. #1 fuse box fire 06' GT
    Donating Users
    Aug 2014
    Utah
    Greeting,
    My fuse block caught fire and I can't get my car running right. Looks like the low beam relay melted a hole right through the entire fuse block taking out the wiring harness that goes into the cabin. I've bought other fuse blocks from junk yards and none match. I re-spliced all the wires from the harness and stuck all the pins where they appear to go and the car runs but it has no horn and wipers, also the low beam is intermittent. Sometimes the low beam works but it won't turn off and other times it won't come on at all unless i flick the relay.
    The fuse block from a 06 Grand Prix GT is very difficult to find, perhaps that might be the problem. I would like to be driving this car once again, any thoughts on this electrical issue before I part out the car?
  2. #2 Re: fuse box fire 06' GT
    Oct 2014
    portland oregon
    maybe you got a wire crossed? and/or if you used the same relays as were in your burned up box maybe they got to hot when the low beam burned up and are now malfunctioning.
  3. #3 Re: fuse box fire 06' GT
    Donating Users
    Aug 2014
    Utah
    Maybe so on the low beams, I need to start with the correct fuse block. I priced it at the dealer and its $650 which I don't have at the moment.
  4. #4 Re: fuse box fire 06' GT
    Tried the JY yet?
    04 Comp G.
  5. #5 Re: fuse box fire 06' GT
    Donating Users timboku's Avatar
    Montgomery, IL
    I have a fuse box off a 06gt if you need it..have to dig it up.
    2002 GTP..DD.. Topswapped Gen V L26, XP cam, Full Size IC, E85, 2.6 Pulley,SD Headers, K&N Intake, N*/Lq4,FP Rewire, TEP Trans, F body Fronts, GXP Rear Brakes, LE Spoiler, AGXs with vogtland springs, bonni gxp rims, Timboku Tuned
    1995 Cutlass Supreme Convertible...Soon to be L32Swapped.....2005 GXP Stock
  6. #6 Re: fuse box fire 06' GT
    Donating Users
    Aug 2014
    Utah
    Quote Originally Posted by timboku View Post
    That would be awesome! is that the one from under the hood? Thank you in advance!
  7. #7 Re: fuse box fire 06' GT
    Montgomery, IL
    Quote Originally Posted by herb101 View Post
    Yup its from under the hood..I'll dig it up tonight after work
  8. #8 Re: fuse box fire 06' GT
    Donating Users
    Aug 2014
    Utah
    Thank you
  9. #9 Re: fuse box fire 06' GT
    Donating Users
    Aug 2014
    Utah
    I learned some things about my fuse block. I recently got the correct fuse block from timboku (thank you!) and the blocks have letter identifiers to match cars, mine is a "PC" electrical system. I happy to have the right fuse block however, I still have issues with my wipers, horn, and low beams. The engine harness has a black and white stripe wire that burnt the insulation off on several places. Does any one here have any idea how to remove this engine harness that plugs into the fuse block? This looks like an electrical nightmare. thank you in advance.
    herb101
  1. Fuse tap for wiper fuse.
    By Stormhaven in forum Audio, Security & Visual Electronics
    Last Post: 07-11-2013, 12:24 PM
  2. Help...not getting fire
    By Knightmare in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-16-2012, 10:48 AM
  3. #1 Cyl Mis Fire
    By 88ironduke in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-30-2010, 07:58 PM
  4. my a$$ is on fire...lol
    By cojo in forum General Tech Discussion
    Last Post: 05-10-2009, 09:32 PM
  5. Mis-Fire #5
    By gtbeach in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-06-2009, 11:39 PM
