Thread: RPM jumps when releasing gas pedal/ cruise control
Results 1 to 3 of 3
  1. #1 RPM jumps when releasing gas pedal/ cruise control
    Aug 2015
    Minnesota
    Hey everybody!
    I have a 2001 Grand Prix SE with a 3100 in it. The car has 135k miles on it. For the last 10k miles or so the rmps have started to jump when either the gas pedal is released or the cruise control is disengaged. It is much more drastic when the cruise control is disengaged. Usually the RPMS rapidly jump somewhere between 200-1000 rpms in a split second before going back down to what they should be at. This is happens much less drastically when releasing the gas pedal, but still happens. On top of this the car has other problems including a knock and a pressure control solenoid that is malfunctioning in the transmission. I was wondering if anyone had any ideas to what could be causing the problem
    Thanks for any input!
  2. #2 Re: RPM jumps when releasing gas pedal/ cruise control
    Dec 2013
    ohio
    When my cruise quit working it would gain speed and not turn off. Could be unit or have you checked for any vacuum leaks?
  3. #3 Re: RPM jumps when releasing gas pedal/ cruise control
    Perhaps the trans codes are making the torque converter unlock more prominent.
    Because when you do let off the gas at cruising speeds, the torque converter will unlock and the rpm should rise slightly and then fall back down as the rpms and vehicle speed get reduced.
  1. ABS, traction control light and no cruise control?
    By dirtdriver11 in forum Brakes/Suspension/Chassis
    Last Post: 07-30-2012, 10:19 PM
  2. ABS, traction control light and no cruise control?
    By dirtdriver11 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-30-2012, 07:14 AM
  3. brake pedal jumps when applied
    By tipatalon in forum Brakes/Suspension/Chassis
    Last Post: 02-22-2011, 06:17 PM
  4. Traction control, ABS and Cruise control dont work
    By Adamcc91 in forum Brakes/Suspension/Chassis
    Last Post: 02-04-2011, 05:07 PM
  5. feels like trans or front end jumps shifting gears & after releasing accelerator
    By FlaminWhite97GTP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-02-2009, 09:40 AM
