Thread: Misfire Cylinders 2 & 4
Results 1 to 5 of 5
  1. #1 Misfire Cylinders 2 & 4
    Racine, WI
    Driving the Grand Prix and upon slowly pulling out of a parking stop I thought I heard some bad knock in the engine bay. Didn't think anything of it and after a hour drive hour via interstate I start noticing a slight misfire at idle. Scan and it turns out #2 & #4 are missing. Spray brake cleaner all around and can't find a leak (still pulling 21"mg at idle in park). Pull the plugs and both insulators are cracked and slipped over the electrodes. Replace the plugs and now I only see the misfire on #2. Had a bunch of parts left over from when I built the car and tried wires, coil, computer under coils, and injectors with no help. What are my next steps? Lifter? As I originally broke #2 & #4 simultaneously, could it be the head gasket between the two cylinders?
    Thanks,
    Matt
  2. #2 Re: Misfire Cylinders 2 & 4
    Likely it's the location of the plugs and an bad angle.
  3. #3 Re: Misfire Cylinders 2 & 4
    Mar 2015
    USA
    Did you loose anything off the plugs? If so might want to get a borescope in those plug holes and check out the piston/cyl walls.
    -'04 Impala SS - 3.6 pulley, AL 104s, ZZP DP, PLOG, 180stat, 1.9 rockers, gutted airbox mod, basic tune
  4. #4 Re: Misfire Cylinders 2 & 4
    Racine, WI
    The porcelain is still hanging on, thankfully is was not bouncing around in the cylinders. Last night I did a compression check and all 6 cylinders ranged from 177 to 192 psi. #1 was the lowest at 177 psi and the other 5 where between 188-192 psi Cylinders 2 & 4 were right up there with the highest at 190 psi each. My thought was I blew the head gasket between those two cylinders, however I am now not so sure with the good readings. Possible lower intake leak? I believe I am consuming coolant and cannot find an external leak. Possibly coolant is getting sucked into the head and spraying the spark plugs, breaking the insulators?
  5. #5 Re: Misfire Cylinders 2 & 4
    not a head gasket, you'd have less than a 100 psi if that was the case.
  1. Boring Cylinders
    By Kolton Lock in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-20-2012, 10:23 PM
  2. Who knows how to see in the cylinders?
    By Gasnmyveins in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-05-2011, 08:40 AM
  3. Misfire in all cylinders except #1
    By talontedGTP in forum General Tech Discussion
    Last Post: 06-21-2011, 09:54 AM
  4. What Do 8 Cylinders...
    By blueguy in forum Track Sessions and Kills
    Last Post: 12-20-2008, 01:55 AM
  5. coolant in cylinders
    By rharper33 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-09-2008, 08:25 PM
