Thread: Horn Swith/Trunk Weatherstripping
Results 1 to 3 of 3
  1. #1 Horn Swith/Trunk Weatherstripping
    Aug 2008
    houston , texas
    i noticed that my horn no longer works. the relay under the hood is fine, think its the switch. any body else had this problem?? on another note, i have a leak in the weatherstripping of the trunk, any time it rains everything is wet. is that part only found at a dealership/?
  2. #2 Re: Horn Swith/Trunk Weatherstripping
    SE Level Member frankdatank0's Avatar
    Dec 2008
    Manhattan, KS
    hey man i dunno anything about the horn thing but i have a 99 GTP and the trunk leaked real real bad you got to have someone with a hose spray water on the truck while you look in the truck through the backseat with a flashlight then take like a body hammer and a dolly and fix the metal underneath the weather stripping then got o autozone and get some 3M weatherstripping adhesive and glue that back on and yea its dealer only its like 50-75 bucks dont remember the exact amount but it was really high for some rubber let me know if you need more detail i can try my best
  3. #3 Re: Horn Swith/Trunk Weatherstripping
    Aug 2008
    houston , texas
    cool thanks. ill try that. i think i know where the leak is coming from cuz i found a tear in the weatherstripping. probly came from using my car as a work car.
  1. horn and neon lights
    By Tyler_06 in forum Visual/Body Modifications
    Last Post: 01-17-2009, 09:57 PM
  2. Horn Going off
    By Bruteforce72 in forum General Tech Discussion
    Last Post: 01-12-2009, 01:47 PM
  3. remote door lock horn only when lock ?
    By NEONNIGHT34609 in forum General Tech Discussion
    Last Post: 12-10-2008, 09:05 PM
  4. what is on the horn circuit?
    By Bio248 in forum General Tech Discussion
    Last Post: 11-25-2008, 01:05 AM
  5. 4T65-HD in the trunk?
    By Iron Indian in forum Off Topic Discussion
    Last Post: 02-04-2008, 04:03 PM
