Thread: Please define my Aeroforce Parameters
Results 1 to 14 of 14
  1. #1 Please define my Aeroforce Parameters
    Feb 2015
    california
    I need to know the accurate values or expected readings for the following parameters. Answer as many as you can please and if you can explain their importance. Im wanting to figure out which 8 to cycle thanks.
    Mods: 3.5 pulley 3" catted downpipe MSD wires NGK plugs 180 tstat K&N intake zzp Power log borla cat back
    Trans Temp
    MAF SENSOR LB/M
    MAF FREQUENCY
    THROTTLE POS. PCT-
    FUEL %
    IGNITION ADVANCE
    PULSE WIDTH
    SHORT TRIM B1
    SHORT TRIM B2
    LONG TRIM B1
    LONG TRIM B2
    O2 B1
    O2 B2
    IAC
    ENGINE LOAD
    TORQUE CONVERTERSLIP
    TORQUE CONVERTER STATUS
  2. #2 Re: Please define my Aeroforce Parameters
    I posted a thread in the how to section on normal values.. Please take a look for it.
  3. #3 Re: Please define my Aeroforce Parameters
    Feb 2015
    california
    Do you have a subject I can search? I tried searching Aeroforce in the how to section and nothing
  4. #4 Re: Please define my Aeroforce Parameters
    Quote Originally Posted by silenthaven View Post
    Trans Temp 0-220ยบ, anything over 200 is getting warm
    MAF SENSOR LB/M
    MAF FREQUENCY 0-11,000hz. Completely depends on throttle input and how much air is going past it.
    THROTTLE POS. PCT- Ask your foot, thats how far it will be open.
    FUEL %
    IGNITION ADVANCE 0-45ish, again depends on engine demands and throttle input. Cruising around 20-40, wide open throttle 12-16.
    PULSE WIDTH Again, throttle input based. Going slow it will be low, 0-8ish, WOT likely near 13-16ms.
    SHORT TRIM B1 -20 to +20
    SHORT TRIM B2 -20 to +20 un-used.
    LONG TRIM B1 -16 to +16.4, if you ever saw +16.4 you have a vaccum leak.
    LONG TRIM B2 -16 to +16.4, We do not have a bank 1 sensor 2, so that is not even used. We only have 2 o2 sensors and both are called bank one.
    O2 B1 0-990mv, is will always bounce back and forth between random numbers, it's trying to achive the stoich rating of the fuel.
    O2 B2 0-990mv, bounces around untill warms up and stays near the .400 to .600mv range if the converter is working correctly.
    IAC
    ENGINE LOAD ask your foot.
    Over half of those I dont or wouldnt even watch as they are kinda pointless to view.
    Trans temp, intake air temp, coolant temp, ignition advanced, knock retard, MAP in/hgs for vaccum and boost readings, MPG and volts were really the only ones I cared to watch.
  5. #5 Re: Please define my Aeroforce Parameters
    If you are ever looking for something by me.. search on "e asy" without the space and my user name.
    Here's that thread
    http://www.grandprixforums.net/threa...highlight=easy
  6. #6 Re: Please define my Aeroforce Parameters
    Map reads vaccum, all engine create a vacuum while running.
    Different motors make different amount but 95% run around -18 to -20in vacuum at idle, it can go higher on the negative scale to say -23 to -25 with drops in throttle.
    Anything over 0 vacuum is postive, so boost/psi. Most stock L67 3800's make 6-7lbs of boost.
    And our cars only use B1S1 and B1S2. As for bank 1 sensor 1 and sensor 2. We do not use anything that says bank 2 sensor 1/2.
  7. #7 Re: Please define my Aeroforce Parameters
    Feb 2015
    california
    Thanks. What are the correct MAP readings? Also I have a 3" zzp catted downpipe and am reading about 150 with no decimal is that right?
  8. #8 Re: Please define my Aeroforce Parameters
    Feb 2015
    california
    i mean the O2 B2 0-990mv you said reads .400-.600 mine says 150
  9. #9 Re: Please define my Aeroforce Parameters
    If it's always near 150mv and not moving at all, then that sensor could be dead.
    It should be switching back and forth as the car warms up, then most lock in the somewhere around the middle numbers.
  10. #10 Re: Please define my Aeroforce Parameters
    Feb 2015
    california
    I had an auto zone 02 sensor replaced when i put in the downpipe... no enigne codes on my aeroforce..
  11. #11 Re: Please define my Aeroforce Parameters
    Feb 2015
    california
    Didnt you say there are no B2 for the grand prixs? So would I even expect an accurate reading from the O2 B2 0-990mv?
  12. #12 Re: Please define my Aeroforce Parameters
    There is no BANK 2 SENSOR 2.
    We only have a BANK 1 sensor 2, so yes we have a rear o2 sensor it's just called a B1S2.
  13. #13 Re: Please define my Aeroforce Parameters
    Feb 2015
    california
    I don't have a b1s2 just o2b1 o2b2 and o2b3
  14. #14 Re: Please define my Aeroforce Parameters
    Then don't worry about.
    Not sure what else to tell you.
  1. Aeroforce Gauge Parameters
    By GTPJIM in forum General Tech Discussion
    Last Post: 05-23-2014, 12:16 AM
  2. Engine parameters
    By SarasotaGTP in forum General Tech Discussion
    Last Post: 02-01-2012, 08:22 AM
  3. which parameters to run on aeroforce?
    By z3r0 in forum General Tech Discussion
    Last Post: 11-14-2011, 11:43 PM
  4. scan parameters
    By sca555 in forum General Tech Discussion
    Last Post: 03-19-2011, 01:12 PM
  5. Why cant I see parameters
    By deangtp in forum PCM Tuning
    Last Post: 04-14-2008, 06:03 PM
