Thread: Please define my Aeroforce Parameters
Results 1 to 14 of 14
  1. #1 Re: Please define my Aeroforce Parameters
    Map reads vaccum, all engine create a vacuum while running.
    Different motors make different amount but 95% run around -18 to -20in vacuum at idle, it can go higher on the negative scale to say -23 to -25 with drops in throttle.
    Anything over 0 vacuum is postive, so boost/psi. Most stock L67 3800's make 6-7lbs of boost.
    And our cars only use B1S1 and B1S2. As for bank 1 sensor 1 and sensor 2. We do not use anything that says bank 2 sensor 1/2.
  2. #2 Re: Please define my Aeroforce Parameters
    Feb 2015
    california
    i mean the O2 B2 0-990mv you said reads .400-.600 mine says 150
  1. Aeroforce Gauge Parameters
    By GTPJIM in forum General Tech Discussion
    Last Post: 05-23-2014, 12:16 AM
  2. Engine parameters
    By SarasotaGTP in forum General Tech Discussion
    Last Post: 02-01-2012, 08:22 AM
  3. which parameters to run on aeroforce?
    By z3r0 in forum General Tech Discussion
    Last Post: 11-14-2011, 11:43 PM
  4. scan parameters
    By sca555 in forum General Tech Discussion
    Last Post: 03-19-2011, 01:12 PM
  5. Why cant I see parameters
    By deangtp in forum PCM Tuning
    Last Post: 04-14-2008, 06:03 PM
