Thread: Harmonic Balancer
Results 1 to 8 of 8
  1. #1 Harmonic Balancer
    Mar 2015
    Tucson
    I just swapped the old one with a new one, old one was rotted almost all the way threw. But wow for being such a easy job on all the other cars ive done it to this one was a pain in the ass. Took me close to 4 hours to do. The balancer just didn't want to come off at all. It actually bent the bolt to my puller. All I got to say is if you are going to do this for the first time on your own car set some time aside for it.
  2. #2 Re: Harmonic Balancer
    Jun 2012
    Minneapolis
    I'm completely rebuilding a 2000 gtp engine right now and I had the same problem. I found that the easiest thing to use is a 3 jaw puller. Auto stores will rent it out for free.
    Sent from my SM-G386T using Tapatalk
  3. #3 Re: Harmonic Balancer
    If this takes more than 15 minutes..you need new tools.
    Seems like yours was the exception.
  4. #4 Re: Harmonic Balancer
    Jun 2012
    Minneapolis
    Took me about 10min
  5. #5 Re: Harmonic Balancer
    i had mine off 4 or 5 times over 4 days trying to fix a leak, its rather easy if you have a air gun to drive the puller bolt. all i kept thinking is this has to suck balls with only hand tools.
  6. #6 Re: Harmonic Balancer
    With hand tools..you lay the ratchet on the subframe and click the starter (icm disconnected).
  7. #7 Re: Harmonic Balancer
    red neck balancer removal,,,,sounds like a plan!
  8. #8 Re: Harmonic Balancer
    Apr 2015
    Columbus, OH
    Quote Originally Posted by ScottyDoggs View Post
    Works every time! Done it in a few cars. You can't buy a torque wrench with that kind of torque. If only you could do it in reverse to tighten it
    Top Swapped 01 Imp
  1. Harmonic balancer
    By Tone5500 in forum General Tech Discussion
    Last Post: 11-13-2013, 08:01 AM
  2. Well there goes my L67 harmonic balancer...
    By jlgp2007nc in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-07-2013, 02:44 PM
  3. new harmonic balancer, now got KR
    By Juanmiguel in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-06-2012, 07:31 AM
  4. help with harmonic balancer
    By Alcalypse in forum General Tech Discussion
    Last Post: 01-13-2011, 09:04 PM
