Thread: check engine light points to egr
Results 1 to 10 of 10
  1. #1 check engine light points to egr
    Jan 2015
    illinois
    where should i start trouble shooting the egr system ?.explanation ecm detected too little flowon the egr system
  2. #2 Re: check engine light points to egr
    time for a new egr valve, or you can try cleaning it. remove it, then spray brake cleaner in side it to free up the valve.
    if need be i got one for sale http://www.grandprixforums.net/threa...36-parts/page2
  3. #3 Re: check engine light points to egr
    Hold up ... don't replace anything
    Tell us the code. Just because the title of the code says insufficient EGR flow doesn't mean that the EGR is bad. Soooo if it's say something like that. Then you may want to post the code and look for what the FSM says.
    I watched a forum tell a guy that was a reason to replace his egr twice. $320 later the code still plagued him. Took me under 5 minutes to read on Google to find out that the EGR flow is read by the map sensor. At which time the guy said "I glued the map together when part of it came apart a while back". Sure enough the map had failed.
    Sooo if you wanna save the cost of an EGR and being pissed off longer. Please post the code and description
  4. #4 Re: check engine light points to egr
    Enfield, CT
    X2.
    Sent from my LG G3
  5. #5 Re: check engine light points to egr
    Jan 2015
    illinois
    im not sure of the code auto zone scanned it and i dont think there printout gave me a code#.recently had issues w/ a vac line blender box issue i think thought it may havebeen related so i diconnected battery to get the light off when and if it comes on again i'll post .thanks for the replies
  6. #6 Re: check engine light points to egr
    Jan 2015
    illinois
    the code is p0401 should i just buy an egr or is there something else i should look at
  7. #7 Re: check engine light points to egr
    its the egr or a blocked tube, they can get carbon build up in the tube and restrict the flow.
  8. #8 Re: check engine light points to egr
    Holy CHRIST.. does anyone read what I write? Does anyone search Google before just tossing parts on a car?
    When was the last time you saw someone with a clogged EGR tube? Never...ever...not even on a hot summer day.
    Please read #2 under diagnostic aids.
    http://www.gearchatter.com/viewtopic8863.php
    You are welcome.
  9. #9 Re: check engine light points to egr
    Enfield, CT
    Quote Originally Posted by ScottyDoggs View Post
    I believe you are thinking of the 3.4 motors scott
    Sent from my LG G3
  10. #10 Re: check engine light points to egr
    I think...he didn't know about gearchatter or the FSM.
  1. Check engine light
    By jtckf in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-25-2015, 08:48 AM
  2. check engine light
    By kposh25 in forum Northeast
    Last Post: 05-30-2014, 07:53 PM
  3. Check engine light comes on then goes off
    By BeezyPlatt in forum 5.3L V8 (LS4)
    Last Post: 12-20-2012, 01:27 PM
  4. Check Engine Light - Wont downshift, whine coming from engine
    By brandibissell in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-11-2012, 08:17 AM
  5. check engine light and lose wire in engine bay
    By Fcukit33 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-13-2011, 05:29 AM
