Hold up ... don't replace anything
Tell us the code. Just because the title of the code says insufficient EGR flow doesn't mean that the EGR is bad. Soooo if it's say something like that. Then you may want to post the code and look for what the FSM says.
I watched a forum tell a guy that was a reason to replace his egr twice. $320 later the code still plagued him. Took me under 5 minutes to read on Google to find out that the EGR flow is read by the map sensor. At which time the guy said "I glued the map together when part of it came apart a while back". Sure enough the map had failed.
Sooo if you wanna save the cost of an EGR and being pissed off longer. Please post the code and description
X2.
Sent from my LG G3
