Thread: May need new resonator... glasspack?
Page 1 of 3 123 LastLast
Results 1 to 20 of 46
  1. #1 May need new resonator... glasspack?
    SE Level Member MM704's Avatar
    Jan 2015
    Gardner, MA
    So tonight I noticed the exhaust on my GTP was pretty loud. I took a look underneath and sure enough my resonator (2nd resonator this car has had, original one rusted out) has a crack in it towards the front (maybe two or three inches long), pretty close to where the resonator and the downpipe come together. I'm most likely going to see if my mechanic can either patch it up or weld it shut, but if I end up needing a new resonator what would be a suitable replacement? I've heard a lot of people putting glasspacks in place of their resonators on GP's and based off of YouTube videos they sound decent and in many cases close to stock, and they appear to be a bit cheaper than replacement resonators. I currently have a front PLOG, 3 inch ZZP downpipe and stock mufflers. What are your thoughts? Thanks!
  2. #2 Re: May need new resonator... glasspack?
    Fix it if you can or just slap a huge glasspack in there.
    You won't notice much a change even if you need the glasspack.
  3. #3 Re: May need new resonator... glasspack?
    Enfield, CT
    Cut a beer can and wrap it over the leak with hose clamps until you get new resonator
  4. #4 Re: May need new resonator... glasspack?
    Feb 2013
    37.295091, -121.930053
    no first you drink beer from can then you
    Quote Originally Posted by HighOctaneRacing View Post
    best way to beat the summer heat
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  5. #5 Re: May need new resonator... glasspack?
    Enfield, CT
    No really?
    Sent from my VS985 4G using Tapatalk
  6. #6 Re: May need new resonator... glasspack?
    SE Level Member Centauri's Avatar
    Sep 2014
    St. Paul, MN
    I had a new resonator welded in last month for $85 out the door.
    1999 Grand Prix GTP sedan
    Speed Daddy headers, 3.25" on a ZZP MPS, high-flow cat, 180
    ° t-stat, Autolite copper 104s, shift kit, ReptileTune...
  7. #7 Re: May need new resonator... glasspack?
    Donating Users EHB's Avatar
    Dec 2014
    Maryland
    i just put a 28 / 2 1/2 inch thrush glass pack on to replace the resonator. the car is actually quieter now than with the resonator. first stop sign i hit i thought the car stalled because it's so quiet. hopefully it'll get a little more sound after the fiberglass melts a little. the only thing i can hear now when i get into the throttle is supercharger whine.
    2000 GTP - 3" Catted DP...ZZP Plog...9" Cone filter...Reptile pcm...3.4 pulley...AL104's
  8. #8 Re: May need new resonator... glasspack?
    Apr 2015
    Columbus, OH
    That's exactly the kind of review I'm looking for. Thanks! You have a link to the exact gp you installed?
    Top Swapped 01 Imp
  9. #9 Re: May need new resonator... glasspack?
    Dec 2014
    Maryland
    Quote Originally Posted by bandook View Post
    here it is at amazon , i bought mine at advance auto , same price...thrush
    24214
    http://www.amazon.com/Thrush-24214-G.../dp/B00029J3KM
    it's 2.5 inches in / out , so it's a little bigger than the stock exhaust. had to weld an adapter piece on the back end and i welded a new flange on the dp end because the old one was shot. you can get the 31 inch ,2.25 in / out (# 24205) but i wanted the 4 inch body instead of the 3.5 for better flow .. at least it does in my mind..lol
    this is the flange i used to connect to the DP...much heavier than the stock resonator flange
    http://www.amazon.com/Dynomax-41806-.../dp/B0015KU072
    bought it from rock auto along with a new gasket (cheapest price). they might have the GP too.
    why pay 70 - 80 dollars for a resonator when you can use a 25 dollar GP and get the same results ? i have zero drone. actually i can't hear exhaust at all...lol ...damn dynomax turbo mufflers !!!
    keep in mind that Glass packs DO get louder over time as the fiberglass melts.
  10. #10 Re: May need new resonator... glasspack?
    i got the thrush 32 inch cut the inlet tube off and welded it to the body of the G/P. got the flange at the local muffler shop for ten bucks. even with the headers and no cat it was quiet. added a cat its still the same, no difference in sound at all, still quiet lol how i like it.
  11. #11 Re: May need new resonator... glasspack?
    Dec 2014
    Maryland
    Scotty i don't know how long yours has been on , but have you noticed it getting even a little bit louder ? i wasn't looking for noise , but i at least would like to be able to hear how the car is idling. i can hear it for about the first 30 seconds after a cold start.
  12. #12 Re: May need new resonator... glasspack?
    Apr 2015
    Columbus, OH
    Thanks, just ordered.
    Top Swapped 01 Imp
  13. #13 Re: May need new resonator... glasspack?
    Dec 2014
    Maryland
    no problemo.
  14. #14 Re: May need new resonator... glasspack?
    Apr 2015
    Columbus, OH
    Now all I need to find is a set of used SS catback and I'm set. I'm thinking with two mufflers it will be even quiter, I hope. Yeah, I would prefer if it sounded like an electric car. Only thing I want to hear is blower whine
    Top Swapped 01 Imp
  15. #15 Re: May need new resonator... glasspack?
    its no louder 3 years later now. and i added the headers after i already had the glass pack.
    the new bottom swapped engine also is dead quiet.
  16. #16 Re: May need new resonator... glasspack?
    Oct 2011
    Toledo, OH
    On the topic of resonators, the Walker one I had installed less then a year ago failed this week in a way I'd never seen before. The spiral corrugated lining came loose inside the housing. Sounds like someone playing the triangle though my exhaust. Initially thought it was my cats heat shield bouncing around.
    Oh well, gotta go get an alignment today anyway, might as well pay them to slap a glaspack in too.
    7"
  17. #17 Re: May need new resonator... glasspack?
    Oct 2011
    Toledo, OH
    So I got the Thrush 24214 replacing the Walker OEM style resonator and holy crap is it way way quieter.
    7"
  18. #18 Re: May need new resonator... glasspack?
    Jan 2015
    Gardner, MA
    Thanks for all of the responses guys. My resonator ended up breaking all the way through by where it connects to the downpipe (open exhaust... REALLY loud haha). My mechanic ended up welding it back together but I'm not sure how long that will last mainly because the crack was surrounded by rust. I'm skeptical about the glass packs idk how long they usually last, but they're cheap so I'm not ruling them out. I was looking at a magnaflow one (#18145) made of aluminized steel for like $60 maybe I'll try that.
  19. #19 Re: May need new resonator... glasspack?
    Dec 2014
    Maryland
    did you even read the posts ? industrialfish said he's replacing his resonator after only one year and scotty said his glasspack is still going strong after 3 years. guess who's cost more ? you can buy 2 glass packs for the cost of that one resonator. maybe the res will last a little longer, maybe not , but it ain't gonna outlast 2 gpacks.
  20. #20 Re: May need new resonator... glasspack?
    Oct 2011
    Toledo, OH
    Granted, I got my resonator on eBay for $50 and bolted it on myself. But the Thrush was only $26 plus $53 to have the shop put a flange on it and weld the other end in.
    7"
  1. Replies: 24
    Last Post: 05-06-2013, 08:57 AM
  2. 05 GP GT Resonator went out. Replacing with Glasspack (Cheaper) Recommendations?
    By mbyrne159 in forum General Grand Prix Discussion
    Last Post: 09-01-2012, 03:25 PM
  3. Resonator or glasspack
    By TDgrand in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-13-2011, 05:31 PM
  4. Glasspack resonator Length
    By GOTIT4CHEAP16 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-24-2011, 11:37 PM
  5. Cabin drone: Glasspack vs. Resonator
    By Bedwards in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-25-2010, 04:04 PM
