Hi I jus bought a 2000 GT. Noticed there is water under the mat on pasenger side front. What could be causing it? The door seals are pretty could and the sunroof does not leak. PLEASE HELP
If you look in the How To section you will find a solution to this. Or you could also send a PM to Abrasive or Reptile and they have a fix for you.
Moved this to the correct area also.
