Thread: diagonal support braces bolt sizes please?
Results 1 to 8 of 8
  1. #1 diagonal support braces bolt sizes please?
    Buffalo
    I need the size for the (4) lower ones that attach to the radiator support and the (2) upper ones that are larger and fit into the strut towers
    Also the (4) "clam shell" bracket bolts that are visible, not the ones inside the radiator support bar
    I am trying to get these in stainless or even socket-head type to clean up the engine bay
    Ive taken them to the parts store trying to match them up best I can, and I cant get them either in stainless or at all
    Thanks in advance
    PS
    Also the bolts to hold the coil packs in place. The l26 ones I saved are too thick , no idea where the l67 ones went
  2. #2 Re: diagonal support braces bolt sizes please?
    Did you check the bolt size thread? Oh nevermind that just says what size the head is. And I assume you are looking for like the thread pitch and length.
  3. #3 Re: diagonal support braces bolt sizes please?
    Buffalo
    honestly - no lemme look for it real quick - nope just says the socket size needed to remove them
  4. #4 Re: diagonal support braces bolt sizes please?
    Buffalo
    In case anyone else is wondering
    I think the top bolts , the ones in the strut towers are
    M10x40mm 1.50 pitch?
    I think the ones in the radiator support are
    M8x25 1.25 pitch?
  5. #5 Re: diagonal support braces bolt sizes please?
    hangover park IL
    yup
    l67 and l36 coil bolts are 5 and 4mm
    i just drill and tap em to 10-32 and use much stronger nicer and cheaper stainless philips hardware
    ~James~ Psychotic Gearhead
  6. #6 Re: diagonal support braces bolt sizes please?
    Buffalo
    Thanks again James!
    im not too sure about the drill/tap skills I may or may not have. Just looking for a quick fix to replace the rusty hex head bolts.
    Even the supercharger bolts like the vacuum tree and pcv cover.
    Next mission - new coil pack bolts
  7. #7 Re: diagonal support braces bolt sizes please?
    hangover park IL
    it's probably cheaper to buy a 10-32 tap and bolts then it is to buy 6 4 millimeter bolts that are long enough
  8. #8 Re: diagonal support braces bolt sizes please?
    Buffalo
    You sir have a good point - looking into getting that today after work
  1. ZZP diagonal braces
    By SgtMarshal in forum For Sale - Parts
    Last Post: 09-27-2013, 07:24 AM
  2. MODIFICATION Painting the diagonal braces
    By rellik01 in forum Detailing Tips and Tricks
    Last Post: 01-03-2013, 04:27 PM
  3. Diagonal Braces 04+
    By Confusingboat in forum Brakes/Suspension/Chassis
    Last Post: 11-15-2012, 01:29 AM
  4. ok to drive without diagonal braces for a short time?
    By 2000GTP in forum Visual/Body Modifications
    Last Post: 09-29-2008, 09:17 AM
