Thread: Broken exaust manifold bolt
Results 1 to 14 of 14
  1. #1 Broken exaust manifold bolt
    Jersey
    ok so today it was around 10* outside and so i decided to put on my new PLOG from zzp. Anyways the installation was going smoothly until i was torquing down the last manifold stud and then, SNAP! my worst nightmare, the bolt broke off and left the shank inside of the head (the one where the dipstick bolts to). I drove around for a couple of hours to see if i had a leak or not, and luckily i dont. Is there an easy way to get the bolt out or is it a remove the intake manifold and heads project?
    P.S. Gen V Top swap is on the way, probably by late spring or summer. Would it be ok to leave in the shank until then?
    16' wrx sti- stock
  2. #2 Re: Broken exaust manifold bolt
    Donating Users pissedoff02grandprix's Avatar
    Jan 2009
    Shepherdsville KY.
    Can you feel the threads? are they at the top? or can you see the broken bolt?
    2002 White GP SE 3100 Tinted Tails soon to be De-Badged as well as a coming 3400 top swap.... To Be Continued......
  3. #3 Re: Broken exaust manifold bolt
    Jersey
    the broken stud is almost even with the head of the motor, you can just barely see it
    16' wrx sti- stock
  4. #4 Re: Broken exaust manifold bolt
    Jan 2009
    Shepherdsville KY.
    well if no leak now in the cold that you have I doubt it will leak later on but who knows.
    being you are doing a top swap in the near future i would just let it go.
  5. #5 Re: Broken exaust manifold bolt
    GT Level Member Clar2478's Avatar
    Nov 2008
    Idaho
    alter on you will probably just have to do something like tack on another bolt to the part that is sticking out so you can remove it with a socket.
    Call me Brad
    '06 GT: Just a few mods here and there.
  6. #6 Re: Broken exaust manifold bolt
    Jersey
    I didn't get that lucky, its just about even and in there a little
    16' wrx sti- stock
  7. #7 Re: Broken exaust manifold bolt
    Jul 2008
    Poteau Oklahoma
    you can get an eazy-out "kit" at autozone, comes with various size drill bits and easy-outs.
    you drill a hole in the broken stud and put the easy-out in the hole giving it a slight tap with a hammer and then use a wrench at the end of the out and back the broken stud out.
    easy as busting your knuckles and cursing, alot.
    98 chevy truck
    83 Olds cutlass
    86 Olds cutlass
    06 se gold
  8. #8 Re: Broken exaust manifold bolt
    Jan 2009
    Shepherdsville KY.
    yeah but where he has his problem I don't think he can get to it with out dismantling the thing. I would hold off being you are doing the top swap, not really a big deal.
  9. #9 Re: Broken exaust manifold bolt
    Charles City, IA
    If it is not leaking, I would not worry about it since the heads are coming off sometime soon anyways.
    SMGPFC Two Nipple General
  10. #10 Re: Broken exaust manifold bolt
    Jul 2008
    Poteau Oklahoma
    well if he is doing a top-swap then it probally isnt a big deal, but if he is going to be driving it for a while before doing so then it would be in his best intrest to fix his mess.
    98 chevy truck
    83 Olds cutlass
    86 Olds cutlass
    06 se gold
  11. #11 Re: Broken exaust manifold bolt
    GT Level Member Vegas~Blown's Avatar
    Aug 2008
    vegas
    unless I'm missing something how does a top swap help with removing an exhaust bolt out of the head? The might be a little more room to look at the problem but with the head on the car the space issue remains.
  12. #12 Re: Broken exaust manifold bolt
    Jan 2009
    Shepherdsville KY.
    Well if he does the top swap as many others have it makes sense to pop the heads while you are there have them worked and ported to match the intake and decked and replace the head gaskets ....
    atleast that is how I do mine...
    better to do it while you are already there right?
  13. #13 Re: Broken exaust manifold bolt
    Aug 2008
    vegas
    Quote Originally Posted by pissedoff02grandprix View Post
    using that logic one might as well remove the crank for a look see while you're at it. that's not saying that doing head work isn't beneficial, but to call it out as part of a top-swap seems a stretch, to me.
  14. #14 Re: Broken exaust manifold bolt
    Jersey
    A top swap is swapping heads from a L67 and adding a supercharger, then putting them on my L36.
    16' wrx sti- stock
  1. Broken Spring
    By pski920 in forum Brakes/Suspension/Chassis
    Last Post: 06-22-2009, 10:53 PM
  2. Ported exaust manifolds
    By 99prixgt in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-20-2008, 02:39 PM
  3. HUD...Broken?
    By JCG's-GTP in forum General Tech Discussion
    Last Post: 06-27-2008, 12:33 AM
  4. thoughts on the SLP "Power Flo" exaust
    Last Post: 06-22-2008, 07:15 PM
  5. Broken mount
    By David99GTP in forum The Rant Forum
    Last Post: 03-04-2008, 02:05 PM
