Thread: Broken spring
Results 1 to 8 of 8
  1. #1 Broken spring
    SE Level Member Drive XR7's Avatar
    Cleveland, OH
    I'm always posting new broken **** with this GP. I'm so mad with it. Fix one thing, another thing breaks.
    I pulled into my driveway and heard a huge clunk. It was coming from the rear. I pulled the wheel off and found this:
    The spring is broke. Rubbed up against the tire but not enough to cause significant damage or puncture it.
    I will replace both rear struts to get it over with. I would rather not mess with a spring compressor -- I've read Monroe has an all-in-one spring/strut assembly. I've never done this job before, so not entirely sure what I'm getting into. Tips? Is the standard Monroe quick-strut a good replacement part?
    http://www.amazon.com/gp/product/B00...Q6FCKC2P8BBWFV
    http://www.amazon.com/Monroe-171662R...ywords=171662R
    Jason
    2001 Bronzemist Pontiac Grand Prix GTP - SOLD!
    2003 Sonic Blue SVT Mustang Cobra Convertible #2421 (1 of 340)
    2013 Ruby Red Ford Edge Limited EcoBoost
  2. #2 Re: Broken spring
    St. Louis
    Quickstrut should be fine. I think you need a wratchet wrench to get to the top strut bolts inside the trunk as they're in a not so nice spot. Other than that PB Blaster the crap out of all the bolts a few days prior and away you go.
  3. #3 Re: Broken spring
    Antioch, IL
    air ratchet fits just fine in the trunk
    2009 Challenger SRT8
    Expert at being gay.
  4. #4 Re: Broken spring
    Cleveland, OH
    Replaced both rear struts over the past 2 days. The first side was much harder than the second. I couldn't get the bolt to budge out of knuckle, after pounding on it with a hammer and air hammer. Eventually I got it out, but the bolt started to bulge since I was banging on it for so long. I had to grind it back down to get it back into the knuckle. The second side was a piece of cake, no major issues. Thank god for air tools.
    Jason
  5. #5 Re: Broken spring
    GTP Level Member 99GT2dr's Avatar
    Cibolo, TX
    Move out of the rust belt if stuff like this displeased you.
    '11 Suburban LTZ
    '99 SSEi
    '99 GT
    '09 G8 GT
  6. #6 Re: Broken spring
    SWPA
    Quote Originally Posted by ITHURTZ View Post
    I don't think one will on 04+. The lack of space is disappointing and disturbing.
  7. #7 Re: Broken spring
    Antioch, IL
    04+ ftl!
    Xr7 you replace that end link? Because dam that looks like a chewed pencil! (30 second change with impact)
  8. #8 Re: Broken spring
    Enfield, CT
    Had no issues with my 06 and I have no space issues at all
    Sent from my LG G3
  1. broken spring in seat?
    By Pontiac Racer in forum Introductions/Noob Questions
    Last Post: 12-12-2014, 01:36 AM
  2. Performed broken spring fix on HUD, still nothing?...
    By rizer in forum Audio, Security & Visual Electronics
    Last Post: 01-29-2013, 04:59 PM
  3. Bent pushrod and broken valve spring?
    By brokenmercy in forum 3.1L V6 (LHO/LG8)
    Last Post: 03-07-2011, 05:31 PM
  4. Loose Ignition Key, Broken Spring?
    By Stormwolf in forum Engine
    Last Post: 10-25-2010, 06:29 PM
  5. Broken Spring
    By pski920 in forum Brakes/Suspension/Chassis
    Last Post: 06-22-2009, 10:53 PM
