Thread: Diy ac repair question
Results 1 to 7 of 7
  1. #1 Diy ac repair question
    Jan 2013
    Detroit
    What is going on everyone, beautiful lazy Friday and its 80 out.
    I charged the AC today, ICE COLD AIR....Obviously I was out of freon so there has to be a leak somewhere, it is not just going to vanish. I charged it up with the r134a Auto Zone brand, they had a deal 2 for 20 without the hose, I had a hose laying around for a different car. Charged it up to 45psi.
    I'm dealing with a 2004 Pontiac Grand Prix, it was working fine last summer, but was hot this summer. I would like to repair what I can with the AC, what are some cheap things that I CAN do, basically where are the o-rings that everyone talks about, are they just the 2 o rings at the compressor? I am sure that I will have to take it to the shop and find the leak, but before that would like to see if I can eliminate the leak with a simple solution.
    Thank You guys!
    Paul
  2. #2 Re: Diy ac repair question
    O rings are cheap. But find the leak. Look for it like you would any other leak.
  3. #3 Re: Diy ac repair question
    GXP Level Member
    Mar 2015
    Tomball
    Charge it with a can of R134 with the ultraviolet dye in it, then buy a black light bulb from walmart, just the regular CFL style and find the leak. Common leaks I have found are the actual schrader valves and the compressor just behind the clutch. You also need to be able to read the high side as well 40-45 is good for low side but being able to read both will tell you more about the system as a whole. If you end up with sky high high side pressures you could end up with other issues too.
    Jeff
  4. #4 Re: Diy ac repair question
    GTP Level Member Impala131's Avatar
    Knoxville, TN
    Quote Originally Posted by J57ltr View Post
    Jeff
    I did this same thing for my old GTP, I bought a kit with the UV die, blacklight, and tinted glasses to help you see the dye. Works best to look for the dye at night. In my case, I had a compressor leak and there was dye all over my hood and belt system. Hopefully you will have something easy.
    2003 Grand Prix GTP.... the journey begins again....
    E85 Self Tune with HPT, 80# Injectors, Gen V 3.4 pulley, SD Headers, AL605 Plugs
  5. #5 Re: Diy ac repair question
    GXP Level Member
    Mar 2015
    Tomball
    That dye can be a PITA, but I think it's worth it. It gets all over my gauges, but I have old house towels that I use for cleaning up. At night using the CFL that stuff lights up like the fourth of July, the ones that use LED's are pretty good too as long as you get the right wavelength. Incandescent "black lights" don't work at all, so avoid those.
    Jeff
  6. #6 Re: Diy ac repair question
    Enfield, CT
    NAPA sells o-rings kit specific to your car. It has every o-ring for your ad system not that you need every one. Also they have genuine due kits with a UV light. 45 psi??? The system takes less than 2 IIRC
  7. #7 Re: Diy ac repair question
    GXP Level Member
    Mar 2015
    Tomball
    It all depends on temperature. You cannot tell how much freon is in a system just by low side pressure.
    Jeff
  1. 1998 GTP supercharger repair kits repair cost
    By SpecialK in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-17-2015, 10:49 AM
  2. Rim repair?
    By mteschGTP in forum Tires & Wheels
    Last Post: 10-07-2013, 11:32 AM
  3. bumper repair question
    By 01gtp1506 in forum General Grand Prix Discussion
    Last Post: 07-16-2013, 11:24 PM
  4. Dent repair question.Is this possible?
    By MyteeMyk in forum Visual/Body Modifications
    Last Post: 06-12-2012, 06:47 PM
  5. Question about EBCM repair.
    By sk8erdude in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-07-2012, 03:02 PM
