Thread: robber boot club
Results 1 to 11 of 11
  1. #1 robber boot club
    SE Level Member lostscout's Avatar
    Sep 2014
    Cold Lake Alberta Canada
    Good afternoon gang
    got a split in the rf outer cv boot....the split is new, the axle is quiet....need a how to in the replacing the boot....anyone?
  2. #2 Re: robber boot club
    Remove the entire axle and reboot it.
    Or just buy a new axle which is faster and easier and no messing with grease.
  3. #3 Re: robber boot club
    SWPA
    I'm with FFDP. Replace the axle. You will thank yourself later.
  4. #4 Re: robber boot club
    Dec 2012
    Where 4T65E's were born
    Replacing the outer boot alone is a bit of a pain, since you have to separate the joint, clean it, and reassemble it. Inner joints are simple, since there is no joint to disassemble, which also makes it easier to clean. If you do both boots at the same time, you can get away with not having to separate the outer joint, making it easier. I replaced the inner boot on mine when it ripped, since it was so straightforward. I'd say either you replace both boots or replace the whole axle. At that point, even I would just put a new axle in.
    Sold.
  5. #5 Re: robber boot club
    check on Napa remans. It's beyond cheap and they stand behind them.
  6. #6 Re: robber boot club
    Buffalo
    Lifetime warranty is 1 time replacement only *
  7. #7 Re: robber boot club
    You gotta stop pissing people off. Advance warrantied about 50 axles for me
  8. #8 Re: robber boot club
    Buffalo
    I guess ? Whenever I have them out , I would warranty them. On the 2nd attempt Napa said its a one-time exchange ?
  9. #9 Re: robber boot club
    Sep 2014
    thanks for all the advice guys....did the boot anyway....we'll see what happens....worst problem I had was the stupid tierod end.....nut wouldn't come off....end up cutting the "hold" end of the stud and cutting the nut...all good now
  10. #10 Re: robber boot club
    SWPA
    Next time pry down on the top of the tie rod. It will keep it from spinning so the nut will come off.
  11. #11 Re: robber boot club
    Sep 2014
    actually I did...I am a licensed mechanic (been out of the trade a long time....actually since fwd was abnormal).....and used my whole bag of tricks....
  1. Help with inner tie rod boot
    By nukkinfuttz in forum Brakes/Suspension/Chassis
    Last Post: 05-27-2014, 01:53 PM
  2. Ohio Grand prix robber
    By Taz Magister in forum The Rant Forum
    Last Post: 07-01-2011, 11:05 PM
  3. Inner tie rod boot
    By bonerjamz03 in forum Brakes/Suspension/Chassis
    Last Post: 10-16-2010, 08:40 PM
  4. NEW CLUB Kentuckiana Grand Prix Enthusiast Club COME JOIN!!!!!
    By pissedoff02grandprix in forum Midwest
    Last Post: 07-15-2009, 05:12 PM
  5. NEW CLUB Kentuckiana Grand Prix Enthusiast Club COME JOIN!!!!!
    By pissedoff02grandprix in forum Off Topic Discussion
    Last Post: 01-16-2009, 07:35 PM
