that sucks.
post some pics of your vac lines and such, maybe we can spot something not right.
that sucks.
so bet your ac or heat dont change directions ie: floor vent defrost......does it? that broken line on the sc vac tree, is that capped off? or open air?
and i cant tell where what line goes where in your pics. zoom out some.
oh, if that vac tree is a open port, theres your issue for sure. its supposed to be hooked up to the line off the fire wall, it works the hvac.
04+ does not use the middle vac tree line.
lets hope thats a cap on the tree then and not a open line end busted off.
My HVAC is all electronic actuators, (but "manual" controls) the AC works at all levels. Under The front of the SC has 2 outlets one to the MAP and the other to the BBS. The MAP side it Teed to a mechanical boost gauge inside the cabin. The tree on top is brake booster, the other (red) is bypass valve and the middle is a cap.
Jeff
