Thread: Well that differential is toast.
Results 1 to 12 of 12
  1. #1 Well that differential is toast.
    May 2012
    Where winter never ends
    2000 Regal - Winter Beater
  2. #2 Re: Well that differential is toast.
    hangover park IL
    god its amazing how fast the PM gears come apart in things....they chip and shatter instead of cracking or bending....
    ~James~ Psychotic Gearhead
  3. #3 Re: Well that differential is toast.
    May 2012
    What causes this? Power? Did I miss a bearing?
  4. #4 Re: Well that differential is toast.
    hangover park IL
    what does the ring gear look like?
    they are not very impact resistant....shock loading from slip n grip
    drop a PM rod onto the floor, half the time it'll snap in half...drop a cast L36 rod onto the floor....and youll probably have to beat the **** outta it with a hammer...and then it'll bend...not shatter
    PM is cheap mass production of parts just strong enough to last 100k.
    they also tend to wear down quite quickly and end up with more and more backlash.
  5. #5 Re: Well that differential is toast.
    May 2012
    Ring gear is destroyed. Also what is a PM rod :/
  6. #6 Re: Well that differential is toast.
    May 2012
    Powdered metal!?
  7. #7 Re: Well that differential is toast.
    May 2012
    Destroyed meaning missing teeth
  8. #8 Re: Well that differential is toast.
    PM has got to stand for powdered metal parts .
  9. #9 Re: Well that differential is toast.
    hangover park IL
    yes powdered metal.
    all it takes is 1 tooth on each planet to fracture and the chunks will destroy everything else in a snowballing pile of fun.
    worn parts with excessive backlash can do it by ending up with the gears suddenly ridding onto an unworn portion and generating high loads in just a tiny area of the teeth which leads to small chunks and the snowball effect takes out ever larger chunks.
  10. #10 Re: Well that differential is toast.
    HUDSON
    Not that it matters now that the damage is done, but check the thrust washer behind the sun gear, it has probably failed. What happens is it sends chunks of metal in between the gears and the gears then self destruct.
  11. #11 Re: Well that differential is toast.
    hangover park IL
    Quote Originally Posted by QUICKSILVER462 View Post
    its a Torrington bearing not a thrust washer. but yeah good point....far too often i seee folks do horizontal installs without using petroleum jelly to stick em into the pockets in the correct orientation.
    thing is that you cant get the diff cover flush if its not in the pocket correctly....there will be a gap that you can only force and possibly snap the diff cover ears off
  12. #12 Re: Well that differential is toast.
    thats not gmr diff correct? and id assume this is destroyed build trans?
  1. Are these pretty much toast?
    By asite57 in forum General Tech Discussion
    Last Post: 01-30-2013, 10:40 PM
  2. I'd say it's toast
    By jwjones in forum Off Topic Discussion
    Last Post: 01-12-2012, 07:30 AM
  3. Yeah toast!
    By afallucco in forum Off Topic Discussion
    Last Post: 01-15-2011, 08:20 PM
  4. 3rd gear toast
    By izup69 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-15-2009, 07:03 AM
  5. Last of a dying breed! A Toast.
    By Toofastgs in forum Off Topic Discussion
    Last Post: 05-03-2009, 07:17 PM
