Thread: bad smell coming out of air vents.
Results 1 to 14 of 14
  1. #1 bad smell coming out of air vents.
    Dec 2014
    Remington IN
    I did a quick search and haven't found the thread. I know I've read about it on here. We have a bad smell coming out of air v ents. looking for the remedy. Thanks in advance.
  2. #2 Re: bad smell coming out of air vents.
    GTP Level Member bonerjamz03's Avatar
    Apr 2009
    Upper Darby, PA
    What kind of smell?
  3. #3 Re: bad smell coming out of air vents.
    Dec 2014
    Remington IN
    Dead
  4. #4 Re: bad smell coming out of air vents.
    you cabin filter is wet and nasty. its under the wiper cowl, pass side.
  5. #5 Re: bad smell coming out of air vents.
    Dec 2014
    Remington IN
    Ok, Thanks.
  6. #6 Re: bad smell coming out of air vents.
    Or something got in there and died.
  7. #7 Re: bad smell coming out of air vents.
    follow this thread to open up the cowl. http://www.grandprixforums.net/threa...-Permanent-Fix
    if the filter is wet, or was wet, follow that how too and change the deflector there, its like 5 bucks.
  8. #8 Re: bad smell coming out of air vents.
    GTP Level Member Impala131's Avatar
    Knoxville, TN
    Funny this should come up, I just put deflectors in both of our Impalas last night, following that same guide. $3.31 each on GMPartsGiant (plus shipping).
    Everyone should do this, when I bought the red car it had a bunch of water in the back seat area.
    2003 Grand Prix GTP.... the journey begins again....
    E85 Self Tune with HPT, 80# Injectors, Gen V 3.4 pulley, SD Headers, AL605 Plugs
  9. #9 Re: bad smell coming out of air vents.
    Dec 2012
    Where 4T65E's were born
    Since he didn't post what he drives, I see he made an intro thread with a 98 GTP. Which in that case they do not have filters, correct?
    Sold.
  10. #10 Re: bad smell coming out of air vents.
    Dec 2008
    Lawndale, CA
    No they don't come with one but one can be added.
    These little guys are pretty potent and will neutralize a lot of odors within the AC system. This is just one scent. Works very good and lasts a long time.
  11. #11 Re: bad smell coming out of air vents.
    ac shop my ex used work at used pine sol in a spray bottle, fan on full to vents, then spray at the pass side foot area, this disinfects the vents and makes the car smell like pine big time.
  12. #12 Re: bad smell coming out of air vents.
    hangover park IL
    Mold on the evaporator.
    make sure to shutoff the a.c. a minute or two before you park to allow the water condensate to drain and the fan dry off the evaporator.
    Parking with a wet evaporator isn't good once the car gets a mold infection
    ~James~ Psychotic Gearhead
  13. #13 Re: bad smell coming out of air vents.
    Dec 2012
    I always shut the ac off when I pull onto my subdivision, leaving just the fan on until I get home. When the a/c worked.
    Sold.
  14. #14 Re: bad smell coming out of air vents.
    Dec 2014
    Remington IN
    yep 98 GTP. and by the way the motor swap is going real good. running like a charm. new gaskets everywhere bolt in plug in and we gone. but all of a sudden my daughter says the air system smells like a dead hog.
  1. Stink coming from air vents
    By 2007GrandPrixGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-23-2014, 05:40 PM
  2. Replies: 3
    Last Post: 04-11-2014, 08:05 PM
  3. smoke coming through the a/c vents
    By bonerjamz03 in forum General Tech Discussion
    Last Post: 08-19-2009, 07:05 PM
  4. Air condition/vents smell when turned on! How do I fix?
    By Freebeer187 in forum General Tech Discussion
    Last Post: 08-08-2008, 12:54 PM
  5. 2000 GP SE rich fuel smell out of vents this morning.
    By StreetChariot in forum General Tech Discussion
    Last Post: 04-29-2008, 08:54 AM
