Thread: When coil pack module is connected the wire harness gets hot and smokes *UPDATE*!!
Results 1 to 20 of 26
  1. #1 When coil pack module is connected the wire harness gets hot and smokes *UPDATE*!!
    Nov 2014
    Minneapolis, Minnesota
    Hi, I am almost finished with my L67 swap in my 1998 intrigue, but I have run into a real issue. So far I have every wire connected to every sensor/plug minus the MAP sensor (adapter is on it's way) and when I hook the negative cable to the battery I get a big arc and if I tighten it down I get smoke coming from the engine harness plug that goes to the cam, crank and then the Ign control module. I tried some simple deducting like disconnecting the cam and crank sensor and leaving the ign control module still plugged in and it smoked. So I then took the old harness that has just the and plugged the old ign control module in and same thing smoked and got hot again. *Also engine will not crank. I don't know what to do any ideas are more than welcome. Thanks.
  2. #2 Re: When coil pack module is connected the wire harness gets hot and smokes
    Kemmerer, Wyoming
    I would probably look at the ground real closely with something like that happening
  3. #3 Re: When coil pack module is connected the wire harness gets hot and smokes
    thats a good one. make sure your battery cables and grounds are hooked up right.
  4. #4 Re: When coil pack module is connected the wire harness gets hot and smokes
    Nov 2014
    I have checked the grounds, I too think it looks like a common ground issue where the wires are looking for the nearest possible connection.
  5. #5 Re: When coil pack module is connected the wire harness gets hot and smokes
    Feb 2013
    Missouri
    What harness\PCM are you using? Obviously something has a dead short to ground somewhere.
  6. #6 Re: When coil pack module is connected the wire harness gets hot and smokes
    Nov 2014
    I was able to use the pre-existing wire harness that was in the car as it was originally a n/a l36 engine. So no mods to the wire harness and as far as the PCM goes I had Overkill make me a tune because there were no intrigues to ever have a SC'd L67 engine.
  7. #7 Re: When coil pack module is connected the wire harness gets hot and smokes
    Feb 2013
    Missouri
    Let me look at some schematics, something is shorting to ground somewhere. Have you tried disconnecting the ICM, crank, and cam censor (basically only leaving the ICM harness grounded_.
  8. #8 Re: When coil pack module is connected the wire harness gets hot and smokes
    Nov 2014
    Yes, I've disconnected the cam and crank sensors and ICM. I found that I can leave the cam and crank sensor hooked up, but not the ICM. The ICM is what seems to be not getting along with the rest of the harness.
  9. #9 Re: When coil pack module is connected the wire harness gets hot and smokes
    Feb 2013
    Missouri
    It's the factory ICM from the L67? Have you tried a different ICM? Pull it off an look at the pins, maybe one of them got bent or something.
  10. #10 Re: When coil pack module is connected the wire harness gets hot and smokes
    Nov 2014
    Yep its the one from the l67. The pins look good. I also tried the ICM from the l36 that was in the car and its harness and same thing.
  11. #11 Re: When coil pack module is connected the wire harness gets hot and smokes
    Feb 2013
    Missouri
    Where do you have the ICM harness grounded?
  12. #12 Re: When coil pack module is connected the wire harness gets hot and smokes
    Nov 2014
    right behind the pulley mount
  13. #13 Re: When coil pack module is connected the wire harness gets hot and smokes
    Feb 2013
    Missouri
    Which wire is smoking?
  14. #14 Re: When coil pack module is connected the wire harness gets hot and smokes
    Nov 2014
    The entire weatherpack connector and at the ICM
  15. #15 Re: When coil pack module is connected the wire harness gets hot and smokes
    Feb 2013
    Missouri
    With the ICM harness disconnected, hook the battery up and check for voltage at any of the pins. Nothing should have voltage with the key off.
  16. #16 Re: When coil pack module is connected the wire harness gets hot and smokes
    Nov 2014
    I'm gonna check tomorrow, but I'm pretty sure there is because the key has been off the whole time.
  17. #17 Re: When coil pack module is connected the wire harness gets hot and smokes
    any chance you got the battery pos and neg cables mixed up at the starter and the ground on the tranny? seems like the engine is hot. with power that is.
  18. #18 Re: When coil pack module is connected the wire harness gets hot and smokes
    Nov 2014
    That's a possibility, the two cables were like identical.
  19. #19 Re: When coil pack module is connected the wire harness gets hot and smokes
    Feb 2013
    Missouri
    That's your sign right there. Disconnect both and check for continuity between positive and negative.
  20. #20 Re: When coil pack module is connected the wire harness gets hot and smokes
    Nov 2014
    Ok, so I checked the wiring at the starter and found that somehow one of the wires that I had bolted to it was actually the ground wire that is supposed to be grounded to the block according to a friend of mine. Anyway now the short is out of the way I have a new problem. Now the fuel pump actually primes like it is supposed to, but the now when I turn the key the engine will not turn over. I had the starter out and it tested fine so it isn't the starter. And yes I checked the neutral safety switch incase that helps any.
  1. Same coil pack keeps going bad
    By xxburkettxx07 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-26-2015, 06:54 PM
  2. Replies: 3
    Last Post: 01-06-2013, 10:53 PM
  3. coil pack
    By chancinit666 in forum General Tech Discussion
    Last Post: 06-13-2010, 12:22 AM
