Well that's good news, though I would have used the dye marker stuff so you can figure out where the leak is. Make sure to get your pressures correct you should be at about 240 psi on the high side and 40 on the low side. This changes slightly with temperature but where you are at the temp isn't that high so just use that as a reference.
