Thread: Fuel line twisted!!
Results 1 to 5 of 5
  1. #1 Fuel line twisted!!
    Mar 2015
    indiana
    I went to change fuel filter and it wouldn't come off I looked at it and the actual fuel line is twisted and kinked right at the fitting that screws into filter any way to fix this or do I have to buy whole new fuel line
  2. #2 Re: Fuel line twisted!!
    St. Louis
    As long as it's not leaking then it should be ok, but how bad is it kinked? Pic? It sounds like you didn't hold the line side steady and turn the filter to remove it instead of just trying to remove the line itself without holding the filter. They are known to do this when they rust up.
  3. #3 Re: Fuel line twisted!!
    Mar 2015
    indiana
    It's kinked pretty bad the bad thing is I can't get filter off bc it's right behind the nut that you are suppose to turn I wasn't sure the best way to repair it
  4. #4 Re: Fuel line twisted!!
    you can get a dorman fuel line repair kit.
    lock the line nut down, aka dont move it, then use a wrench to turn the filter off the line nut.
  5. #5 Re: Fuel line twisted!!
    St. Louis
    PB Blaster could be your friend here as well before you try it again.
  1. WTB: fuel line from injectors to fuel filter for 99GTP coupe
    By Swole in forum Wanted To Buy - Parts
    Last Post: 08-25-2014, 02:36 PM
  2. The retainer/clip the secures the fuel line to the fuel rail.
    By Sudden in forum Wanted To Buy - Parts
    Last Post: 06-22-2013, 05:20 PM
  3. fuel line nut rusted to fuel line!!
    By Pepino in forum General Tech Discussion
    Last Post: 08-12-2010, 08:25 AM
  4. Fuel line to fuel filter cracked need help asap
    By Jays98GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-30-2010, 04:20 PM
  5. Custom AN Fuel Line setup for PRJ Fuel Rails... [*]
    By Iron Indian in forum How To Write-Ups/Tech Tips
    Last Post: 01-17-2009, 07:53 PM
