Thread: are these springs the blue ls6 springs people are talking about?
Results 1 to 18 of 18
  1. #1 are these springs the blue ls6 springs people are talking about?
    Jan 2014
    minnesota
    I have acquired a set of beehive springs that have a blue stripe on them that look very similar to the yellow springs. I am curious if they are the same spring or which one I should use. I have a set of the blue stripe and a set of the full yellow painted springs
    I am putting on my gen 5 top swap top, 2007 n/a block, stock cam, stock everything. However in the near future I will be planning on upgrading the rockers I believe to either 1.8 or 1.9, so I would like to upgrade the springs while I've got the heads off because the rockers are easy to do with the engine together.
    I would also like to know if it is ok to run the stock retainers and clips. I have read in many places that it's OK and it's not okay, but many of the threads that I found were from the early to mid 2000 and some of them were newer like 2013 or so. I could not find a definitive answer one way or the other for the stock retainers and stock clips.
    Edit to add pic...
  2. #2 Re: are these springs the blue ls6 springs people are talking about?
    Dec 2013
    ohio
    You need modified LS retainers. Can you post pics of springs? I have some I know for sure is, I just need to dig them up, then i could give you my guess.
  3. #3 Re: are these springs the blue ls6 springs people are talking about?
    Enfield, CT
    Get the Manley retainers from Intense racing
  4. #4 Re: are these springs the blue ls6 springs people are talking about?
    Feb 2013
    Missouri
    The stock retainers won't work out well. They preload the LS springs by .080" for starters. Spend the $35 and get Intense retainers. Why not L76 springs? Your timing dampener will thank you.
  5. #5 Re: are these springs the blue ls6 springs people are talking about?
    Jan 2014
    minnesota
    these just happen to be part of a box of stuff I bought from a guy on Craigslist, so that's why I didn't get the l76 Springs. I won't be running a kim in the car, that's why I assumed the stock retainers would be fine, if that's not the case then I'll just have to buy the right springs, retainers, and clips.
    I can post pictures of them, I just need to get out to the garage and grab them out of the box and upload them. Give me a few minutes. But they look just like these, but the blue stripe doesn't go all the way up on the spring and it's light blue.
    http://www.slponline.com/mm5/i/parts/53003-1.jpg
  6. #6 Re: are these springs the blue ls6 springs people are talking about?
    Feb 2013
    Missouri
    You can reuse your stock locks, but you want at least LS retainers. The Intense retainers are basically the same price as LS retainers. You'll want a magnet on a stick, makes getting the locks out a lot easier. Might as well do Viton valve seals while you are that far in there, too.
  7. #7 Re: are these springs the blue ls6 springs people are talking about?
    Jan 2014
    minnesota
    Here are the ones I have. Come to think, they may not even be stock ls6, maybe aftermarket ls6 springs????
  8. #8 Re: are these springs the blue ls6 springs people are talking about?
    Jan 2014
    minnesota
    and they are the same height as the ls6 Yellow Springs both are taller than the stock springs
  9. #9 Re: are these springs the blue ls6 springs people are talking about?
    Feb 2013
    Missouri
    Thought these were the blue LS6 springs, but I could be wrong.
    http://www.summitracing.com/parts/nal-12499224
  10. #10 Re: are these springs the blue ls6 springs people are talking about?
    Jan 2014
    minnesota
    Figured it out, comp cams 26918, old style. Looks like I'll be using the yellow springs i think.
  11. #11 Re: are these springs the blue ls6 springs people are talking about?
    Jan 2014
    minnesota
    After doing some research I would have to agree. I wonder what these are?
  12. #12 Re: are these springs the blue ls6 springs people are talking about?
    Feb 2013
    Missouri
    L76s, yellows have too much spring rate.
  13. #13 Re: are these springs the blue ls6 springs people are talking about?
    Jan 2014
    minnesota
    If I stay stock rocker, could I use the yellows and stock retainers?
  14. #14 Re: are these springs the blue ls6 springs people are talking about?
    No you still need the LS still retainers unless your keeping stock springs. It's $20-25 just spend the coin.
    04 Comp G.
  15. #15 Re: are these springs the blue ls6 springs people are talking about?
    Feb 2013
    Missouri
    The stock retainer should never be used with an LS spring, at all. ever.
  16. #16 Re: are these springs the blue ls6 springs people are talking about?
    GTP Level Member
    Jan 2015
    Lincoln, NE
    the reason you cant use the stock retainers is that the installed hight of the stock retainers is like .100" less then with the ls retainers among other things. just dont do it!
    - 2001 Grand Prix XGT -- 11.21@124MPH
    - 2010 Chevy 2500HD LTZ -- Car hauler
    - 2011 BMW 328i Xdrive -- Wife's Daily
    - 2014 Ford F250 crew cab -- 6.2 liters of ford fail
  17. #17 Re: are these springs the blue ls6 springs people are talking about?
    Feb 2013
    Missouri
    ^^^^ .080" That's what I was talking about above.
    Things like this happen:
  18. #18 Re: are these springs the blue ls6 springs people are talking about?
    Jan 2014
    minnesota
    OK, I'll order the right ones.
  1. Replies: 14
    Last Post: 11-23-2013, 04:23 PM
  2. Replies: 39
    Last Post: 02-04-2013, 10:42 AM
