I'll start first. These are going on the lemon.
some head pictures on one page and more on the next. Ported L32 heads done by Chris Hinson aka orangeL67
http://i1115.photobucket.com/albums/...psc6205970.jpg
I did these a few years ago for my comp g. It made some pretty good power.
Had ZZP Stg 2 heads till they cracked when I ran 10.9. Ran SUPER lean on the wideband. +18.
Was able to get a set of L32 heads from Steve Chesser.
Then sent them to Chris Hinson.
orangel67 on here.
His FB page is Bully-Flo Racing Heads
Heads came out amazing. I paid him to go all out. Even did a 3 and 5 angle valve job.
He guesstimates my heads to flow 215 CFM intake @550 and 240+ @600
With these heads and other upgrades I'm doing now I'm shooting for low 10's
Here are pics.
ya'll arent doing the exhaust port to header transitions correctly....unless your running custom headers with a 30* upward swept primary....
your exhaust tubing is at a 90* angle to the gasket surface...it doesnt help your airflow much to have a sharp turn.
you want to open up the roof for sure, but more must be removed from the port roof midway between the valve guide and the port exit to help curve the airpath so its a smoother transition.
unless your sure of having no core shift castings to start with it'd probably be smart to have the thickness sonic checked as some of the ****ty heads can be thin at the coolant passage.
unshroud the valves more and clean up the chamber at the casting to machined area's.
if your not sure you can use a variety of cheap picks to scribe your bore onto the head through the spark plug hole to help you keep from removing too much material
Yeah, I wish I would have had time to build the headers for that car like I wanted to, but oh well. It would have taken a lot of time, and not been much of a gain on that car.
Mine should be here in the next few weeks![]()
600hp +
ZZP S4's.
Not those are your e85 heads NIH (no intercooler heads)
That's ironic
https://m.facebook.com/Handcraftedah...r?ref=bookmark
There's a ton of pics of my work here
My lord guys, Chris does amazing work, I just paid for a set of his heads like yesterday and am stoked to see them. Ya'll need to chill out
