Thread: Idles funny and oil in exhaust. please help!
Results 1 to 11 of 11
  1. #1 Idles funny and oil in exhaust. please help!
    Jul 2014
    Michigan City IN
    2001 grand prix gtp 3800 II supercharged. i just replaced my LIM gastket and the upper plenium. Ive checked all my vacuum lines and did vacuum leak tests but cant figure out why my car is idling so rough. it throws a code for vacuum volume i believe and i noticed that there were black specks in the snow outside of garage when i run it which i am assuming is oil. checked my oil and it was 3 quarts low. please help!
  2. #2 Re: Idles funny and oil in exhaust. please help!
    you replaced the supercharger? cause that's the upper plenum
    Check the pcv
  3. #3 Re: Idles funny and oil in exhaust. please help!
    Jul 2014
    Michigan City IN
    well they call the gasket the plenium. so id have to pull the super charger again wont I?
  4. #4 Re: Idles funny and oil in exhaust. please help!
    also.. please post the actual code and it's definition
  5. #5 Re: Idles funny and oil in exhaust. please help!
    Jul 2014
    Michigan City IN
    i had a vacuum line that disconnected on my way back from a 25 mile trip which broke when i was working on it. i just drove it home and its sat there ever since if that matters at all.
  6. #6 Re: Idles funny and oil in exhaust. please help!
    Not to check the pcv
  7. #7 Re: Idles funny and oil in exhaust. please help!
    Jul 2014
    Michigan City IN
    P0101
    Mass or Volume Air Flow Circuit Range/Performance Problem
  8. #8 Re: Idles funny and oil in exhaust. please help!
    Unplug your maf..then start the car
  9. #9 Re: Idles funny and oil in exhaust. please help!
    Jul 2014
    Michigan City IN
    okay ill do that in a second. but might sound noobish but i have my pcv infront of me now. how do you tell if its bad or not?
  10. #10 Re: Idles funny and oil in exhaust. please help!
    Jul 2014
    Michigan City IN
    ive checked the pcv and its good. ive cleaned the MAF could it just be that the MAF is bad?
  11. #11 Re: Idles funny and oil in exhaust. please help!
    Jul 2012
    Marengo, Illinois
    If it runs better with the MAF unplugged then its bad. Try a junkyard for a cheap one. They usually run about 25 bucks
  1. 06 grand prix reduced engine light on turns over idles funny gas does nothing
    By stumpee1 in forum General Grand Prix Discussion
    Last Post: 01-24-2013, 11:50 PM
  2. bad idles
    By MGRead in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-29-2012, 06:18 PM
  3. 08 idles and runs bad
    By JJB in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-06-2012, 08:52 PM
  4. Idles for 5 seconds then dies
    By 00grandprix in forum Engine
    Last Post: 04-30-2011, 04:32 PM
  5. car idles shakes
    By handymontana in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-15-2010, 01:45 PM
