Thread: My abs and check tire pressure light on
Results 1 to 11 of 11
  1. #1 My abs and check tire pressure light on
    GT Level Member Jonarin's Avatar
    Oct 2014
    Hi, I have a 97 Grand prix gt. Both the abs and check tire pressure light is on and sometimes when I drive for long enough the Trac off comes on. So I went to a nearby shop that scanned my abs code for free, got lucky.... and they said I had all 4 bad wheel sensors, and said my car probably had a bad abs module.. anybody have this problem too that can confirm that's what it is?
  2. #2 Re: My abs and check tire pressure light on
    whats the codes?
  3. #3 Re: My abs and check tire pressure light on
    Oct 2014
    All he said was it was for all 4 wheel speed sensors
  4. #4 Re: My abs and check tire pressure light on
    The Boss Iceman6669's Avatar
    Jun 2011
    My 97 does the same thing. It could be wheel bearings (which is where the sensors are located.) OR IT could be a bad EBCM. I have a bad EBCM.
    2011 F-150 Yote powered
  5. #5 Re: My abs and check tire pressure light on
    Oct 2014
    I'm thinking it's a bad ebcm.. should I even bother with it.i know it's an arm and a leg
  6. #6 Re: My abs and check tire pressure light on
    Jun 2011
    I never did.
  7. #7 Re: My abs and check tire pressure light on
    Oct 2014
    Yeah I probably won't either.
  8. #8 Re: My abs and check tire pressure light on
    snag one from a junk yard, or ship it off to module masters, they charge like a 100 to rebuild em. they test them too before they rebuild, if it tests good they send it back.
  9. #9 Re: My abs and check tire pressure light on
    Jun 2011
    From what I was told you can NOT just get one from the junkyard unless you want to have it reprogrammed at the dealership.
  10. #10 Re: My abs and check tire pressure light on
    you 97 guys got this gem? bolted to the master? if you take the whole master and abs pump off from a junk yard theres no reprogramming. its not even reprogram, but it needs to be "re homed" cost me 30 bucks at the local garage.
    i have a spare one. but once its taken off the bad master it will need to be re homed. sanp onabs scanner is what the guy used, tech 2 will also re home it.
    you need to take the pump apart to get it off the master, then the servos will unwind. they are what needs to be reset.
  11. #11 Re: My abs and check tire pressure light on
    Enfield, CT
    I have a 97 abs pump for sale
  1. Check tire pressure light stays on
    By Jonarin in forum General Grand Prix Discussion
    Last Post: 10-12-2014, 05:37 PM
  2. ABS Light+Low Trac+Check Tire Pressure Problem
    By 1997gpgt in forum Brakes/Suspension/Chassis
    Last Post: 08-11-2011, 10:18 PM
  3. ABS and check tire pressure light on
    By GTP2188 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-18-2010, 02:12 PM
  4. ABS and check tire pressure light on
    By GTP2188 in forum Brakes/Suspension/Chassis
    Last Post: 11-15-2010, 07:00 PM
  5. Check Tire Pressure light on with no low pressure.
    By DanGTP in forum General Tech Discussion
    Last Post: 11-13-2008, 08:43 AM
