Thread: Need some measuemants, for a 98 Grand Prix SE, Thanx
Results 1 to 9 of 9
  1. #1 Need some measuemants, for a 98 Grand Prix SE, Thanx
    Sep 2011
    Southern Alberta, Canada
    OK I want to measure my car since its home, & see how F'ed up it is.
    I put A, B, & C for points where I would like measured - don't now what years would be the same, but if someone could, that would be great, Thanx
  2. #2 Re: Need some measuemants, for a 98 Grand Prix SE, Thanx
    Jan 2014
    AR
    No dimensional specs required! All you need are comparative measurements, in an "X" pattern, rather than straight across in three places. For example: center of left front hood hinge bolt head- to -right fender front bolt head center. Know what I mean? That will tell you if its square. If it is, your measurements will match. If you're within a quarter inch, the bolted-on body panels can probably be adjusted to compensate and correct the gaps.
    Other measuring points can be used, but be warned that not everything under that hood is symmetrical. If you select asymmetrical points to measure from, it will make you think its way out of whack. Like the strut tower braces, those bolts are not in the same place side-to-side. I did try to hunt up a diagram for you (underhood unibody dimensions) with the actual specified numbers and measuring points. Did not readily find one, but its more than you need to assess the damage. You can trust me, I do this kind of thing for a living and have plenty of experience and certs to quialfy this advice.
  3. #3 Re: Need some measuemants, for a 98 Grand Prix SE, Thanx
    Sep 2011
    Quote Originally Posted by idrivejunk View Post
    Ok, ill check that way tomorrow. Thanx
  4. #4 Re: Need some measuemants, for a 98 Grand Prix SE, Thanx
    Other measuring points can be used, but be warned that not everything under that hood is symmetrical. If you select asymmetrical points to measure from, it will make you think its way out of whack. Like the strut tower braces, those bolts are not in the same place side-to-side. I did try to hunt up a diagram for you (underhood unibody dimensions) with the actual specified numbers and measuring points. Did not readily find one, but its more than you need to assess the damage. You can trust me, I crash these cars for a living and have plenty of experience and certs from fixing them repeatedly.
    Fixed that up for you. Seemed like it was worded oddly.
  5. #5 Re: Need some measuemants, for a 98 Grand Prix SE, Thanx
    Sep 2011
    Ok, I measured X-wise today - & it is 3/4" @ the strut to 2 1/2" @ the front where the frame meets the rad support.
    & more good news the other insurance company ruled in my favor & now just have to see how much I get.
  6. #6 Re: Need some measuemants, for a 98 Grand Prix SE, Thanx
    Jan 2014
    AR
    Quote Originally Posted by heavydtheogre View Post
    HeavyD, could you possibly re-phrase this, if you wish further assistance? I'm not sure what you mean by it.
    Bill, take a long walk on a short pier.
  7. #7 Re: Need some measuemants, for a 98 Grand Prix SE, Thanx
    Sep 2011
    It actually does not matter, the car is going to be a write off.
    Thanx.
    So this thread can be closed.
  8. #8 Re: Need some measuemants, for a 98 Grand Prix SE, Thanx
    GT Level Member Yarbeau's Avatar
    Jun 2010
    Edmonton
    What are they giving you for it?
    2000 Daytona 500 - Tog Headers with catted Downpipe, EGR Delete, 180* Thermostat, Solid engine mount, Poly tranny mount/Dogbones, K&N CAI with a custom tune.
  9. #9 Re: Need some measuemants, for a 98 Grand Prix SE, Thanx
    Sep 2011
    Quote Originally Posted by Yarbeau View Post
    Don't know yet, have to wait for an adjuster to call me.
  1. 2004 Grand Prix Comp GTP Rear Fenders/Quarters and Grand Prix Parts***
    By luckydogaroo in forum General Grand Prix Discussion
    Last Post: 01-30-2015, 04:00 PM
  2. Replies: 23
    Last Post: 06-21-2013, 12:52 PM
  3. Finding Grand Prix parts or Grand Prix's in Junkyards near you!
  4. 1991 grand prix 3.1 swap into 1996 grand prix 3.1
